Question about Ovens
Blanco oven manual bso 635
Hi our bottom element does not seem to be working properly (model no BSO 635) in that it doesn't heat up past warm at best. Can this be replaced easily? Thanks
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    huuum
    • 750 Answers
    SOURCE: Oven heating element
    Hello rvready
    Welcome,
    You said, We have an OLD (1950-60) Frigidaire wall oven, model # RBG-94. Bottom heating element has gone out. Oven is still in good shape so we'd like to be able to find an element replacement, but have had no luck finding one.
    unfortunately,
    I am not able to find this part either.
    Anywhere. This oven is to old for parts. But most important is that it is causing you high utility rates!
    Today's appliances save you the arm and the leg that such an old oven is costing you.
    You have no idea how it is sucking your money out of your pocket!
    It is unfortunate, that no one told you about this years ago!
    You payed for more than one oven with your utility bill if you had it since it was new. My advice is do not put good money into bad!
    Shop for a new one and see your bills go down.
    my wife was telling me to replace the air and furnace for 7 years and I said, it's not broken. But it was over 20 years old. She was right, cause the new one saved me $100. a month!
    That means I threw away $7000. in 6 years with my old world attitude.
    Yes I am old fashion and always fix it!
    But after 25 years of marriage. i finally realized she is a good evaluator and I was a fool to not appreciate her gift for all these years! And out tons more money than I told you about!
    Hope I saved you some bucks with my real life stories!
    Don't tell your wife!!!
    Huuum
    Posted on Oct 17, 2008
    barkencoa
    • 3463 Answers
    SOURCE: smeg oven
    Sounds like you need a new oven element fitting.
    Posted on Dec 08, 2008
    SOURCE: blanco oven not heating
    simple is simple as, replace the element!
    Posted on Oct 09, 2009
    SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
    We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
    Posted on Mar 16, 2010
    Kenmore C970-645121
    The replacement element may be no good
    Apr 27, 2013 | Ovens
    I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
    since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
    Jul 21, 2012 | Ovens
    The oven of my Chef 635 model GSC6635SLP doesn't ignite (no gas comes out in oven, yes from plates), the ignition element is working, there is electricity in terminals connected to thermo valve but it...
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    Oven Problems Replacing the Igniter
    heatman101
    Jul 13, 2011 | Ovens
    Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
    ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
    Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
    The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
    Hope this has been helpful
    john
    May 31, 2011 | Belling Ovens
    Hi i have a Samsung oven bf641fst the light and fan come on but the heat side wont work and the led sceen is blank?
    Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
    May 31, 2011 | Viking VESO176 Stainless Steel Electric...
    TOP OVEN WORKS OK BUT BOTTOM OVEN DOES NOT HEAT UP
    There are a number of reasons why you may find that your oven doesn't heat up, and troubleshooting oven heating elements is not too complicated, so you should be able to manage this in a few hours. When you are trying to decide what is the cause of your oven not heating up properly, you should be able to identify the different problems, and also understand how to repair the oven without too much difficulty. If you find a lot of problems, then you may need to provide a different solution, for example replacing the heating element and fittings completely.
    Heating Element is Broken
    This is perhaps the most common cause of the oven not heating up. The element inside the oven will not become hot if the electrical connections are damaged, or if the element itself is not working. The heating element can be removed and replaced easily, and this is perhaps a very good idea if you have any problems with the heating system of your oven. Test the heating element by firing up the oven with the door open, and your hand close to the front of the element. You should be able to feel it warming up, so if it doesn't, take of the screws which hold it in place, and then unplug the connections. You can take the heating element to a store and they should be able to replace the part for you.
    Hope this help in solving the problem.....
    May 17, 2011 | Ovens
    Bad ignitor? I have a Maytag oven CRG9800BAE displaying F7. No oven heat. Stovetop burners work fine. Got the code cleared, clock is working fine. Is this a bad ignitor? If so, could you confirm the...
    Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
    May 12, 2011 | Maytag Ovens
    Main oven light works fan runs but oven doesn' get warm
    ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
    This video will show you how to replace fan oven element in your
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
    May 23, 2010 | AEG U3100-4 Electric Double Oven
    Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
    I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
    Mar 07, 2009 | Thermador C302U Electric Double Oven
    Ovens Logo
    81 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
