Question about Miele G 1143 SC Dishwasher
Inlet/ drain light on - Miele G 1143 SC Dishwasher
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
How can I clear the intake/drain light on a Miele G2182?
Your pump motor has siezed, it can be removed then spray some penetrating oil abd rotate by hand until the fan spins free and reassemble. Be sure to turn breaker for your dishwasher
May 12, 2014 | Miele Dishwashers
Miele novotronic w145 s spullen light flashes
Possible that this error can be due to the INLET or the DRAIN being clogged or is not functioning. Remove and clean the filter to both the inlet and drain.
Jan 19, 2013 | Miele Washing Machines
Hi, inlet/drain light flushes. checked for
Sometimes the error refers to where the drain pipe connects to the waste under the sink. It gets a build up of gunk over a few years. Just unscrew it and use a chopstick to see if it is blocked. Worked for me
Sep 03, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Inlet/drain light comes on
hi,you need to switch the machine off,open the door and inside at the bottom is your drain ,lift out the filters and get a screwdriver there should be one screw to undo,get a pair of pliers and pull out the part you unsrewd.........have a good look inside there,should be something in there food/broken glass/ anything could be there...............................if not that its your drain pump.......
Mar 25, 2009 | Dishwashers
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Inlet/Drain light keeps flashing
Kenyanjoe, I have had the same problem with a G638 . the inlet/drain light flashed 30 sec after start up, (the machine must empty on start up, this did not happen), This caused it to lock out on alarm I removed the drain hose from the S trap,removed the non return valve from the filter, check the drain pump impellar is free, then blow down the drain hose back into the dishwasher to make sure it was not blocked then found the drain pipe on the S trap under the sink was restricted causing the machine not to empty in time for the cycle to continue causing it to lockout on inlet/drain alarm. Have a go , good luck. GUNNO
Aug 14, 2007 | Miele 24 in. G693 Free-Standing Dishwasher
Miele G 1143 SC Dishwasher Logo
73 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
