Getting message "HDTV Not Support" for few channels on set top box DSE GH5912
When I am viewing the channels through this set top box from **** Smith (Model DSE GH5912) gifted from someone, all channels are appearing after tuning and I am able to view them except 4-5 channels including ABC News 24. I am getting a blank screen for these 4-5 channels and a message on the screen "HDTV Not Support" in a blue backdrop. My TV is a panasonic flat screen slim tv 21". The strength of the signal is good as well. In some channels out of those 4-5 channels, i get an audio but no video. In all these channels (4-5) I get the error message "HDTV Not Support"
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
mistersony
  • 320 Answers
SOURCE: Sony HDTV flat - no picture with HDMI cable and Verizon FIOS box
Probably a handshake problem with the cable box. It is common for cable boxes to have HDMI handshake problems. Hook the box up using the component cables and you should be fine
Posted on Oct 18, 2008
  • 92 Answers
SOURCE: sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
Posted on May 19, 2009
SOURCE: Hi. I now only get
Ok here's the fix, you're only recieivng audio on HD channels because you've got your audio set on automatic or dolby ac-3.
Click menu on your remote, go to a/v settings, then audio and change it to MPEG-1.
Should sort you out.
Posted on Sep 28, 2010
DSE IR CODE G7503
You're asking about the universal set-up codes to this TV; I assumes, and posts this solution. 1157 1052 1130 1142 1027. These are the codes to check. If you wish to get more, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Jul 23, 2013 | Televison & Video
I need the universal remote code for DSE GH5930
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
May 19, 2012 | One For All URC-3445 Remote Control
Does the RCA TV model D52W20 have a digital tuner? or will I need a cable box to watch TV? At our location they just switched the signal. we just had a tube TV with the cable line in the back and up till...
Greetings Pete - No, your display is what is called HDTV ready, meaning it needs a separate tuner AKA set top box.
You need to get the cable box, plug in the component video cables into your TV (usually provided) and plug in audio cables and you're viewing HDTV. See below:
Happy Viewing!
Regards,
Mikeywaf
May 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I am getting a blue screen that says mode not supported when I try to view HD channels
This usually indicates that you are trying to watch a screen in a higher resolution than the Tv will actually handle
Aug 17, 2009 | Televison & Video
Have philips42'hdt.vi,m in australia
You'll have to set up these channels after getting your STB, so yeah, YES.
Mar 25, 2009 | Philips 42PF9731D37 42 in. HD-Ready LCD...
I have a Sony Grand wega im getting fuzy purple diagnol lines
Try changing the component cable to your Video 6 and see if you have the same problem. I tried this and figured out that the set top box from Verizon component connections may be bad. I also tried changing to a different set of component cables to troubleshoot. I figure its the box not my TV.
Mar 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
Unlock code for DSE G2112 required
Hi, I recently bought this model too. I spoke to **** Smith themselves and they assured me that the G2112 is region free out of the box. Have you had a problem?
Feb 17, 2008 | Televison & Video
"Not supported Mode" message
Hook up the component cables on the tv and the dtv box
go to set up on the menu select HDTV or display and deselect all of the 480i and 480p and in some cases also the 720 and only select 1080i to be display. you can then hook up your hdmi cable again and it shoud be supported. Let me know if that works.
Nov 18, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
