Question about Jabra FREEWAY Bluetooth Speakerphone
When I The voice button it's too loud I cannot lower the voice
When I tap the voice comes on too loud and I cannot lower the volume
Did u try lowering the volume from the device which ur using ?
Feb 15, 2014 | Jabra Radio Communications
When I play my DVD and wacth movies, I cannot lower the base/woofter without lowering the volume to the point were I cannot here the voices. Once I raise the volume to here the voices, the action seean...
You don't indicate if the various speakers all sound normal and equal in volume with the test tones, which is where we should start.
Page 25. I would advise setting all controls to nominal (0 dB) and assessing the relative loudness without adjusting them. Then choose the one(s) in the middle, loudness-wise, and adjust the rest up or down to match it.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/LG-LHY-518-Home-Theater-Systems-manual/id/366ag212/t/2/
Jun 03, 2011 | LG LHY-518 System
Verbal text message
My Stuff>Tools>Voice Command and turn it off.
Aug 17, 2009 | LG Vu CU920 Cellular Phone
Lower the volume or disable page/announcement?
For paging u can't change the volume. The only way is to reduce ur phone's speaker volume.
Thanks.
Jul 09, 2009 | NorStar T7316E Corded Phone
Stereo cutting off when volume is over 29
Twenty nine sounds pretty loud to me. A shorted voice coil in any one of your speakers will drop its resistance value so if the amplifier thinks its feeding a short circuit, will "protect" itself by shutting off. Check wiring carefully and each speaker at a little lower volume for sounds of distortion ie: shorted voice coils...
Jun 27, 2009 | Kenwood Marine Receivr/Speaker CD/MP3/WMA...
I recorded my professors lecture and the recorder was right next to her, when I listen back I can barely hear a thing all there is is her voice but muffled because it sounds like a loud wind
During Playback you can press + or - buttons to adjust the volume. Maybe this is your problem. If you need more info watch video instructions chapters for Olympus on http://www.HandBookLive.com under Electronics-> Audio. There are 20 different video chapters. The info about + - buttons for volume during playback was chapter 7 (Playback)
Apr 14, 2009 | Olympus VN-4100PC Digital Voice Recorder
Uniden powermax x 2.4 ghz lost call
If it's in warranty, I would send it back. It sounds like a problem with the built-in amplifier and possibly other components.
The squealing and echo is down to gain being too high, if you cannot set this on the phone, then it's a fixed value in the hardware. If you can, lower the gain. As for not being able to end the call, what about pressing the "c" button or the green button again?
Dec 29, 2007 | Uniden Cordless Phone
Voice commands not turning off
You pressed the space button while in a message.... Hit the space button again when your in a message and it should shut off "audible text" where it reads you your text messages. (you'll notice the guys head on the space button)
Dec 22, 2007 | LG enV VX9900 Cellular Phone
Jabra FREEWAY Bluetooth Speakerphone Logo
18 people viewed this question
Top Jabra GPS Experts
Will Halftowaite
Are you a Jabra GPS Expert? Answer questions, earn points and help others
