Question about Lifetime Toshiba Satellite A505-S6004 Replacement Laptop Power AC Adapter / Charger (91812015122)
Toshiba laptop error code x.c1 also file "autorun.dll" couldnot be loaded or is currupt. ive downloaded several more of the same type of files and they all diplay same message
    Master:
  • Lifetime Master
  • 788 Answers
What software would you run? A lot of software use autorun.dll.
Posted on Mar 04, 2014
How do I get rid of Arcade-1\Cathel-1.Dll Module file error message
It's solved by downloading 'Autoruns' from Microsoft.
Disable the file from running at system startup
Mar 06, 2016 | Toshiba Satellite Computers & Internet
Tip
Create your own autorun CD or DVD
It is easy to create an autorun CD or DVD for Windows and all it takes are a few files (which we've supplied for free). The technique can be used to open other file types, but HTML is used for a reason: it is the most commonly supported by Windows (most PCs have a Web browser) and it is flexible. You could use it to open other files, such as a Powerpoint presentation, but it would require the end user to have Powerpoint or the Powerpoint viewer on their system.
The autorun zip file we've prepared contains everything you need to autorun a CD and open a HTML file. So download a copy - it's tiny and free - see above for the download link.
So why can't an autorun open a HTML directly? It is because a Windows autorun can only open an application (program) not a data file (eg HTML). You cannot tell an autorun to directly open a HTML file. Try it, and nothing will happen. To get around his problem, we are using a .bat file which Windows will treat as a program. This special file will then open the HTML file.
Assembling the CD
Download and copy the files to your root directory of the CD. These are: autorun.inf, autorun.bat and index.html. You can put all sorts of files on the rest of the CD. They won't affect the autorun. You can test the autorun by burning the three files to the root directory of a test CD-R. Open the CD drive and close it again. Viola, you have just created your own autorun HTML CD. You should change the contents of index.html to whatever you need. The index.html supplied is only a test page.
Changes you can make
The autorun can open any type of file and display any message you want. To make changes, open Windows Notepad (do not use Word, WordPad or other Word processors). Now open the autorun.bat file from within Notepad. The order is important, if you double-click the autorun.bat file, it will try to run. So open NotePad and select File-Open and choose the autorun.bat file. You'll see four lines of code.
The first line after @echo (remember the space) will appear as a comment in the autorun launch Window. This comment will be seen very briefly by your end-users. It can be changed to anything you want, but since it only appears for a second or less, don't make it too wordy. If you wanted to say 'The CD is loading now...', the first line of code will look like:
@echo The CD is loading now...
The second line of the code tells the .bat file to open to your index.html file. If want to open a file by another file (eg readme.txt), then it would read:
@start readme.txt
Make sure you leave the last two lines untouched (@cls and @exit) - they must always appear last. Save the changes and you are done. That that's all you need to create your own HTML autorun CD.
on Dec 22, 2009 | Computers & Internet
Message pops up when I start my computer "the specified module could not be found
Run Advanced System Care. It is free and will sort out the registry errors.
Nov 10, 2013 | Toshiba Computers & Internet
XINPUT1_3.dll is missing
Downlaod xinput1_3.dll here: http://www.dll-files.com/dllindex/dll-files.shtml?xinput1_3
Download the zip file, don't download the fixer recommended in this website:
Extract "xinput1_3.dll" to a location on your computer. We recommend you to unzip it to the directory of the program that is requesting "xinput1_3.dll"
If that doesn't work, you will have to extract xinput1_3.dll to your system directory. By default, this is:
C:\Windows\System32 (Windows XP, Vista, 7)
If you use a 64-bit version of Windows, you should also place WDSUTIL.dll in C:\Windows\SysWOW64\
Make sure overwrite any existing files (but make a backup copy of the original file).
Reboot your computer.
For Instant Fix use Reginout system utility
Jan 14, 2013 | Toshiba Satellite L635-S3012BN Notebook
Cant sign on to computer
    • 1 Download the missing comctl32.dll file. Locate a website that offers the comctl32.dll file. You can also use the link in the Resources section.
    • 2 Unzip the download file if it is a .zip-type file. Right-click on the file and choose "extract" to make the file available in a .dll format.
    • 3 Install the missing comctl32.dll file in the proper folder on the computer. If the operating system is 64-bit Windows, copy comctl32.dll to the "C:\Windows\SysWOW64" folder. If the operating system is 32-bit Windows, copy comctl32.dll to the "C:\Windows\System32" folder.
    • 4 Restart the computer by clicking on the "Start" button and selecting the "Restart Computer" option.
    • 5 Open the computer program that previously displayed the error message stating that the file comctl32.dll was missing. This will verify the program now works properly.
Nov 21, 2011 | Dell Latitude D 600/610
My MS Outlook's MAPI32.DLL file is currupted or the wrong version. Pls give me solution for Access Outlook.
hello
try rename mapi32.dll and msmapi32.dll to the .old extension and start outlook or access
if that doesnt work try
1. Delete the contents of the "C:\Program Files\CommonFiles\System\MSMAPI\1033" folder
2. Reboot into normal mode and start Outlook/access, setup will replace the files
with the correct version and Outlok will load as normal.
Oct 07, 2010 | Microsoft Office Outlook 2003 for PC
PowerCinema for Toshiba error message
Here we go, just paste this site in your browser and download the dll. This should correct your problem:
http://www.dll-files.com/dllindex/dll-files.shtml?msvcr71
http://www.instant-registry-fixes.org/how-to-fix-msvcr71dll-errors/
http://www.driverskit.com/dll/msvcr71.dll/2373.html
Mar 07, 2009 | Computers & Internet
Runtime errors
Solution:
i) usually whenever there is virus, spyware, ... in your system some of the .dll will be lost or will lead to curruption or partial currption(some data or all the data in the .dll will be lost)
ii) as such some .dll files are heart or important to run system, some .dll files play mere role.
iii) when such .dll files are lost the program using these .dll files cannot locate or find their .dll files in such you get errors message as u said......
iv) as u debuging is not possible in the normal way until unless you have some debugging program or software such as "Visual Studio 2005" or Visual BASIC TOOLS....
v) due to loss of some important .dll files your system might shutdown frequently..... but you are fortunate that you are getting error message....and these .dll play mere role....
vi) i would suggest to install some best rated antivirus, spyware( Bit Defender -rated top, AVG, Norton....) after perform full system scan try reinstall your OS or format your system or load OS Freshly....
Thanking you
M. Sridhar
Dec 27, 2008 | Computers & Internet
Can't install Magix Movie Pro 12 on Windows Vista
hi, try uninstalling the driver and reinstalling it again, that will replace all the missing files.. let me know
Nov 12, 2007 | Toshiba Satellite A135-S2276 Notebook
Lifetime Toshiba Satellite A505-S6004 Replacement Laptop Power AC Adapter / Charger (91812015122) Logo
Top Lifetime Computers & Internet Experts
Corey Bartlett
Level 1 Expert
Paul Bade
Alan Hohenbrink
Alan Hohenbrink
Are you a Lifetime Computer and Internet Expert? Answer questions, earn points and help others
