I need a manual for LS2403Y tECO AIR CONDITIONER
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
I have a teco split system which stopped working the stand by light has gone off too. Can I fix it.... Lost maual
call teco tech support and they will send you a free operator manual and probably refer you to a local service shop.
Jan 04, 2015 | Heating & Cooling
Teco air conditioner LS1826H fault code F2
F2 on this model means that the indoor unit pipe sensor has failed. You would probably need someone who is at least a licences electrician or preferably an Air con tech to repair this. You will need a new pipe sensor. Contact Teco Australia who can put you in touch with your nearest service Agent.
Sep 09, 2013 | Electronics - Others
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Cant get heating to work
adjust temp e.g. 39 deg Celsius or high and turn on heat,but first you must turn off air conditioner then select heat rating and turn on a.c.
Jul 05, 2009 | Heating & Cooling
I need operating instructions for a teco air con model LT2424YS
I have an TECO Model 7K34STC, that has the two end bearing & housings missing from the opposite end to the motor.
Could anyone tell me of a parts supplyer in Florida U.S.A.
Please reply to
Peter Lawrence
brin4512@hotmail.com
Jun 28, 2009 | Heating & Cooling
Cant get air con to work it is a teco air conditioner
Ours did the same. My husband checked the manual and found that the filters were FILTHY! The filter is at the front of the inside unit. If you still have the manual it will show you where. This fixed ours as it was NOT working at all!!
Mar 01, 2009 | Heating & Cooling
Heating & Cooling Logo
160 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
