Question about Curtis Audio Players & Recorders
Nikai tv external speaker - Curtis Audio Players & Recorders
I have nikai tv.and have a Samsung rimot.how to coad word using.
Samsung TVs remote cant be used for any other brand tv. You have to buy an universal remote for that. there are lost of universal remote available select one which supports NIKAI
www.electro-medical.blogspot.com
Nov 02, 2015 | Samsung Televison & Video
Set nikai tv to english language
Refer its user manual for more details about how to change the display language. If you haven't its user manual with you; visit this site to download it in PDF. NIKAI NDVD1073VR Instruction Manual
Sep 25, 2015 | Televison & Video
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
PhillipssoundBar htl2101A
You have to use the TV remote to set the TV sound option to external. Look on TV setup menu for 'external output' or 'external speakers'.
Dec 15, 2013 | Philips HTL2101/F7 Soundbar Speaker Spkr -...
Do internal speakers need to be off for external speakers to work
I have found in some instances my external speakers need to be off. Mostly if I use my smart TV on Netflix or Amazon Prime. If you have external speakers attached it is better to turn off internal speakers.
Feb 05, 2013 | GE 35GT740 35" TV
Need the codes for a NIKAI TV, that I am using in Iraq.
Hello
Code for NIKAI TV is not listed in the codes of URC-4021. Coreds for NIKKO TV is there. OK.
Mar 05, 2011 | One For All URC-4021 Remote Control
Want to install exterior speakers
Go to menu, use ch. keys and click audio, use vol. keys to go to sub-menu, when sub-menu appears, use ch. key and click down to the tv speakers under heading "speakers", turn them "off". On left side in the back are the audio plugins, the top two under the s-video plugin, red on top, white next down are the two audio speakers rca jacks. Plug your external speakers, like the ones that you'd buy for a computer, in those two. The manual does not say if you plug speakers in these jacks the tv's builtin speakers will be cut off, but this tv I got was being used for a computer monitor and the tv's speakers were turned off from the menu, so I guess plugging in external speakers does not turn off the tv's speakers and would interfer with the external speakers. I suppose you could try it both ways and see, leave the tv's speakers "on" and plug in externals and see if they are turned off automatically.
Jun 04, 2010 | Westinghouse LTV-19w6 Television
I forget my security code of nikai tv
i want service code for nikai tv
May 16, 2010 | Televison & Video
No volume
On the back of your set there are 2 switches that tell the tv whether you are using the internal speakers or the external speakers.
Make sure the switches are set to internal so the speakers in the TV receive the sound signals. If they're set to internal maybe the internal speakers are bad. Set the switches to external and hook up external speakers to the speaker terminals on the back of the TV. If neither setup works then it sounds like an output transistor or related parts.
Sep 01, 2008 | Proscan PS60690 60" Rear Projection...
20 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
