Question about Nikon COOLPIX S610 Digital Camera
LENS ERROR PICTURE NOT CLEAR
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
My picture is not cystal clear. Do I need a Hdmi cable with this tv or some kind of cable for a clear picture?
All HD televisions need HDMI cables for clear picture. If you don't have one, you're not utilizing HD. Opt-World has some good, low priced cables for HDMI.
Dec 01, 2010 | Element Electronics Televison & Video
I cant view the picture clearly while shooting and playback too.i was on a picnic 2wks back,and was taking pictures with my canon SD550 POWERSHOT CAMERA.. all of a sudden the display in the screen blurred...
There is a focuing ring with electromagnets on it, and it swivels to focus. When sand, dirt, lint, or dust works its way into the lens assembly, it can get stuck, failing to focus.
Spray some compressed air into the lens area to try to dislodge it. Then bump it gently if the compressed air doesn't work. Here is a list of things you can try for a jammed lens:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If these don't work, your focus ring is jammed and you will have to fix it or have it serviced. Get an estimate first, since the cost of repair often justifies buying a new camera.
Good luck, these tips might help you.
Aug 27, 2010 | Canon Cameras
Cannot get clear pictures on canon sx110is. Have tried several things. Also have lighting issues
Sounds like the focusing ring in the lens assembly is not freed up, and binding because of dust, lint, etc. You can blow out the lens assembly with compressed air ($4 from Walmart), and try to free it up. You can hold the camera with the lens facing up, and try to "bump" it to free it up also. Short of these things, the camera would have to disassembled to fix the problem, and that's a job. If you decide to have it repaired, get an estimate first. Sometimes it's just better to get a new one on sale. Good luck, hope this helps.
Here's a good web blog about lens error problems, and lens problems, in general:
Jul 12, 2010 | Canon PowerShot SX110 IS Digital Camera
My picture isnt clear. whats the best color setup?
The best way to clear the picture on these sets is to remove the screen and clean the mirrors. If it is still not clear after that it may be a bad lamp or failing capacitors in the chassis. They cause wavy lines and makes the picture blurry.
Jan 31, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Picture is not clear. Has a green tint and glow.
Repalce the coolant in the CRTs. You can get the Phillips CRT coolant replacement kit at www.tvrepairworld.com the kit contains the coolant and the CD with instructions
Oct 13, 2009 | Philips 50P8341 50" Rear Projection...
Our camera was dropped this morning--now it reads Lens Error
oh no! you need to get the camera checked. there might be a lens that got dislocated inside the camera. Nikon is pretty fragile. Get it fixed asap or moist will damage the lens and it won't work anymore.
Sep 03, 2009 | Nikon COOLPIX S10 Digital Camera
It does not shows clear picture
turn the black ring that is around the len's while your cam is on and you can see a picture. ...the black ring will focus your lens. turn till you get a clear picture...turn either one way or the other till picture clears up
Aug 30, 2009 | HP USB Web Camera
Nikon COOLPIX S610 Digital Camera Logo
14 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
