What are the steps to replace the water pump on 1996 lexus es300
Hi, you will need some special tool like : External torx (star)socket, pully and regular tool (# 10,12,14 etc..metric) to change the water pump.
First, you need to clear the room for the job because such as Two belts -(alternator,air cond., pump ect and pully) need to disconnected and take out the plastic cover, tire e.t.c.
There are about ten bolts. The water pump is inside the plastic cover which turns by the timing belt. I strongly recomment to change the timing belt at the same time ($30.00-timing belt- It last about 80000-90,000 miles). Remember to mark the timing gear carefully when you take the timing belt out. This will help you put the timing belt back in the right degree for the engine perform. Water pump can only replace after the timing belt is disconnected.
Take care
