Question about Essick Air Products EP9 500 Whole House Pedestal Humidifier
I just bought the Essickair EP9 500 and the fan does not come on even when I push speed button.
Why is my Aircare tower humififier flashing CF??
clean filter, filter is blocked not letting the air flow through correctly, take the filter out and clean it with warm water and leave to dry before refitting, can use soak but not to much as can damage the filter threads. but warm water will do the job to remove the particles its picked up.
Jan 16, 2018 | Humidifiers
Need essickair humidifier manual
Follow the provided web link. Select from the appropriate category of humidifiers by Essickair, then click on the "More Info" link after which you should choose the specific model humidifier that you own. After doing so you will find a link to the lower right(under "Resources") saying "Owners Manual."
Clicking that Owners Manual link will allow you to open and/or save your humidifiers manual.
Oct 18, 2013 | Honeywell HE360A1027 Whole House...
We just bought an idylis ultrasonic humidifier, but the directions don't make sense. It says to push the button in and wait til it pops out to set the humidity level. It nevers pops out by itself.
I am very fond of my Idylis humidifiers. Best I've ever had. When I bought a 2nd one, I noticed that the HUMIDITY SETTING button had a small sticker on it that said "PUSH TO ROTATE". My larger unit [no longer available] did not have the sticker. And, the sticker instructions are indeed confusing. The button actually has 2 positions 1) when depressed all the way in the settings are locked in place and 2) when pressed in just enough to pop the button up and outward, the button becomes a rotating column that can be turned either L or R to set the desired % humidity. Once the digital readout is at your preference, push the column/button in to lock it down and secure your setting. OMG, so wordy on my part! I think the darn "PUSH TO ROTATE" sticker is not helpful.
Jan 27, 2013 | Humidifiers
Someone gave me moistair 14060 do you have manuls so i know how make it work
Years later...an answer appears!
I have the MoistAir HD-14060, also without a manual. Other than the controls, which are now electronic, this appears to be exactly the same; you can download the manual from the page:
http://www.essickair.com/products/humidifiers/humidifier-categories/moistair-whole-house/hd1407
Sep 12, 2011 | Emerson HDC12 Humidifier
I need to verify that these are calibrated at the factory prior to shipment. if so i need documented proof.
James, I suspect that only the manufacturer can verify and provide documented proof of that, You can contact Customer Service @ 800-547-3888 or you can email them @ info@essickair.com
Apr 14, 2011 | Essick Air 4D7 300 Humidifier
Power light is on, water is up to fill line, dials are set to max humidity and fan speed, but fans do not spin. Tried to spin fans manually but they will not spin on their own. Left fan stopped spinning...
Do the motors feel warm-- maybe even HOT?-- Like they have electric current, but the bearings might be seizing up?
You mentioned one stopped spinning awhile ago--- and the other one was OK-
It sounds like the bearings are dry and worn on the fans-- (How old is the humidifier?)
The bearings CAN be cleaned up and lubricated, if you are into tearing a motor apart, and servicing the bearings-- Are you ready for that? You will have to remove the motors from their mounting, remove the fans, split the end bells, and clean and lubricate the bearings deep inside.
Let us know how much further you want to go-
Mack B
Jan 19, 2011 | Kenmore 14416 Humidifier
Kenmore Humidifier not operating?
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
Dec 08, 2009 | Kenmore Humidifiers
Vicks humidifier v3850 isn't working
does anyone have a problem with a Venta humidifier not working proberly
Feb 27, 2009 | Vicks Humidifiers
Assembly
Here is the link for the user manual for your humidifier; http://www.essickair.com/pdfs/om_hum-400-console.pdf If you don't find what you need in there then try; http://www.essickair.com/service_centers/servicecenter_hap.htm Hopefully they should help. If you still get no luck then please post back again with some more details of what you are having trouble with, maybe post some photos as well and we can try and help :)
Mar 24, 2007 | Essick Air 4D7 800 13 Gallon Humidifier
Essick Air Products EP9 500 Whole House Pedestal Humidifier Logo
77 people viewed this question
Top Essick Air Humidifiers Experts
Mack Baxter
Joseph Mueller
Joseph Mueller
R Daniel Wolfe
Are you an Essick Air Humidifier Expert? Answer questions, earn points and help others
