Question about Honeywell HHT-145 Air Purifier
HPA 160 Air Cleaner won't turn on - Honeywell HHT-145 Air Purifier
Does the ionic breeze blow air
They only move the air slightly. They are not like a conventional fan.
They do not rotate.
They do work effectively for mold spores and dust. If yours has not been cleaned in a while remove the front element from above and spray the stainless bars down with an acidic claener like "Formula 409" and wipe them down after rinsing. On the unit itself unplug it and remove the front and rear grill br pressing a small tab at the bottom of the grille and push upwars. Be careful with front grille as there is an ionizing wire there towards the inside of the unit. If the unit has come from someone else, with an emery board and gentle pressure just make one pass witht he wire gently between board and your finger. drawing towards the spring loaded end. Do the same to the two wires inside the unit housing if present, Witht he rear grille removed, remove the bulb and wipe it down with a cleaner if needed- it should be clear. as it is a UV bulb.
Dust out hte base area with a small paintbrush and remove as much dust as you can from it. If need be a slighly damp rag cna also be used.
With the front of the Ionic breeze unit facing you, there are 2 conductive rubber strips that also need to be wiped down with a lsightly damp rag. They should be removing some black dust. Also wipe down the inside of the front being mindful of the two stainless wires.
Let unit dry off and reassemble.
With left knob turned to left- no light should appear. Turn knob to the right and the UV tube should light and the Boost button should light up blue when pressed once- and green when pressed a second time and then off if pressed a third time. It will only light when the left knob is turned to right.
The right knob adjusts "Low," "Medium" and "High" intensity of the high voltage applied to elements.
Alow unit to dry before powering it on.
A working system should raise the hairs on the back of you hand or give you some other sensation of moving air
Sep 29, 2012 | Sharper Image Ionic Breeze 3.0 Air...
Model s1871sharper image room purifiler. keeps blinking that it is not clean when i just cleaned it
Just check to make sure none of the wires at the front of the unit broken and shorted to an adjacent plate.
Wash the electrode unit with an acidic cleaner like Formula 409, and let it dry, and dust out the cabinet with clean compressed air if you have a source. While this will not alleviate all the red indicator indicators, it will address most of them. The others, you may just decide to live with because the air filer is still filtering/ionizing even if it does indicate it needs cleaning..
Sep 28, 2012 | Air Purifiers
I have the screen inserted but it says i dont and won't purify
Did you clean the contacts that touch the screen? If you need more help with trouble shooting or free information call (336) 499-2505.
Jun 16, 2012 | Ecoquest Fresh Air Air Purifier
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
Ionizer wires get dirty
IT'S THE NATURE OF THE BEAST. IF YOU TRY A ANTI STATIC CLEANER THIS MAY HELP .. JAY THE POOL PUMP REPAIR GUY FLORIDA
Feb 03, 2012 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell Air Cleaner
Is the filter clean?
Are the ionizing wires clean? gently wiping them with 600 grit finishing paper should clean them up and restore perfomrance.
Is unit bent? If so it may be shorting out.
is unit fully seated and making contact?
Jan 31, 2012 | Honeywell FC37A1064 Air Purifier
Crackles even after blades are cleaned
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. To do this, approach the unit from the front, and turn the blade door slightly so the wire can be seen. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Oct 19, 2011 | Ionic Pro TURBO Air Purifier
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have a HoneyWell F300E electronic air cleaner, installed on a furnace in a house I just bought. I have never owned one of these things before. The filter arcs and makes sparking noises constantly,...
Continuous snapping is not normal .Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can.
Jan 05, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Alpine XL 15
Also make sure the safety interlock switch is properly closed when re-assembled. It's the springloaded switch inside the little notch in the chassis - the small tab on the lint screen should fit in and push that switch closed. If you do it wrong, the unit won't work. You should hear an audible click when the tab closes the switch.
Nov 17, 2007 | Alpine Air XL-15 Air Purifier
Honeywell HHT-145 Air Purifier Logo
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
