Question about Dishwashers
Hi, I have just purchased a Stirling dishwasher model number W60A1A401B. I placed it on the ring cycle to test and have now got an E3 error. In the manual it states E3 is a water drainage malfunction? Is there any idea on what may be the issue?
  • 1314 Answers
SOURCE: Error e3?
i need your serial num its important 17
Posted on Jan 04, 2008
SOURCE: Kenmore dishwasher drainage problems
I have the same model -- and USED to have the same problem! We tried lots of things (bleach in the water, etc.). . . . and finally discovered it was a simple, standard concern. The drain tube from the dishwasher to the sink pipe was clogged with grease (looked like lard).
The way i knew it was clogged is that I disconnected the tube from the sink pipe, and tried to blow through the tube. It wouldn't let any air get through.
So once the dishwasher was empty of water (i removed the tube, drained into a big pan, and bailed a lot), we disconnected both ends of the tube.
With the tube in a trash bucket, I blew from one end (cleaned it off a bit first), and the "lard" came out. Drains beautifully now -- and did not require a plumber.
If you do this, be SURE you place the tube back ON the fittings EXACTLY in the same position and shape as before. This makes there are no new kinks or bends introduced into your drain tube.
Hope this helps.
E-mail if further questions!
Jonathan
Posted on Nov 28, 2008
SOURCE: Danby dishwasher E3 error
Same issue here so I just got off the phone with Danby. They said the E3 means the water is not hot enough when it goes into the machine. Now I dont know your guys situation but I let the water run hot until I cant touch it anymore, then I turn on the machine and plug it in. So it sounds like the heating mechanism is not working properly and does not heat the water to the appropriate temp to continue with the cycle. I will say that their support was really friendly and she informed me that since it was purchased less than a year ago it would be covered under the warranty. She gave me the number of a local repair shop. Lets just hope they dont tell me nothing is wrong with it because my water temp is fine. I will let ya guys know. Here is the number for Danby that I called. General office: 419-425-5052. Good Luck!
Posted on Feb 13, 2009
  • 96 Answers
SOURCE: Fault E3 on a kenwood dishwasher...
timer is bad
Posted on Dec 06, 2009
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
My dishwasher gives an E3 error
The E3 error code is not a defined error for this dishwasher. If you are sure it is E3 then best option is to give the controller a reset. This is done by
Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
- "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
Press OFF at this stage. Do not attempt to run the inspection as this could damage the dishwasher unless you are familiar with the what each mode does.
If the Error E3 keeps coming back then call the Samsung technician.
Apr 15, 2014 | Samsung DMR57LF Builtin Dishwasher
E3 Error
the E3 error is a result of water temperature not getting to a nominal value within a particular time. This could be caused by several factors like heater faulty, wash pump not working well, wash arms not circulating water as required. Need model number to help you further pin point if possible.
Refer this site for 60 inch dishwasher and this site for 45 inch ones.
Jan 02, 2013 | Smeg Dishwashers
Hi , I dont have a manual for my ilve intergrated dishwasher but on the display panel its showing E3 cam you tell me what this means. thanks Michael
ILVE modle number WQP12-9319A on the manual it is No 6 which says delatstart time to display booking time or water temperature and when the E3 comes up you
cannot start
Jul 11, 2011 | Dishwashers
My washin machine is just stopping thru cycles and beeping continuously until I switch off - reading E3. My father thinks it might be the heater, is that right. I'm having a lot of trouble getting...
Hi, the E3 error is comes up when the water heater element does not work properly or the filter mesh is blocked. Remedy: Clean the filter mesh and if the problem continues, the main board needs to be replaced.
Jun 24, 2011 | Maytag 24 in. MDB6600A Jetclean II...
Maytag jetclean Model number MJD 3000 AAW Problem : E3 error towards end of cycle
Cause: The water heater element does not work properly or the filter mesh is blocked.
The Filter mesh in the bottom of the appliance.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 14, 2011 | Dishwashers
Kenwood dishwasher Comes up E3
I do not know the Kenwood dishwasher, hence I do not know what the E3 error is, but many dishwashers require a sustained pressure of at least 30 psi.
Can you please post the model number of your Kenwood dishwasher?
Apr 11, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Jul 21, 2008 | Dishwashers
Error e3
Drain pump probably not working. Put machine on cycle 7 and it should turn on the drain pump straight away. you can hear this near the bottom of the machine. if it is silent hten the pump probably needs replacing. I repaired mine be removing it and then dismantle the magnet from the tube then give it a good clean out.
Feb 03, 2008 | Hoover 24 in. HD97E Free-standing...
Dishwasher Hoover HD98E
E3 means water is "not heating" for this model. Check the heating element, thermostat/thermistor or printed circuit board with power OFF.
Sep 11, 2007 | Hoover 24 in. HD98E Built-in Dishwasher
Error e3?
Apr 02, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
588 people viewed this question
Top Dishwashers Experts
Owen Barnes
