Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Kelvinator 14kg twin tub washing machine not spinning. The clutch is rleased from the motor the motor is not turning when switching the power switch.
3 Suggested Answers
  • 1462 Answers
SOURCE: PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Posted on Sep 07, 2008
barkencoa
  • 3463 Answers
SOURCE: Washing machine filling with water when switched off
You need to replace the cold inlet valve as it is sticking.
Please rate my solution.
Thanks.
Posted on May 13, 2009
My frigidaire twin tub washer FWLT1161FDUHWT spin tub stop working what could be the problem
hum what do u mean spin tub no such thing? do u mean the drum does not spin?
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
May 11, 2015 | Frigidaire Washing Machines
GWL11 won't start at all.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Oct 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Why my Washing Machine cannot spin after washing
Jul 07, 2014 | LG Hitachi Washing Machine Lint Filter...
Twin tub washing machine
change the brushes on your motor
Jan 24, 2014 | Washing Machines
Washer will not spin
check the rubber coupling from motor to tub. they are made to break instead of ruining other components. its called a drive coupling. other possible causes-- belt broken, bad lid switch, clutch. check the lid switch first ! the wires going to lid switch can be hooked together and taped. if tub spins now, its a bad switch. but turn off power first!!
Jan 23, 2012 | Washing Machines
My sears washer empties but will not spin.. with the lid switch bypassed I give the tub a spin ,,while the timer is in spin cycle, and the tub starts spinning...but very slow...it seems like the motor...
Your clutch is probably going out, or your transmission. Your clutch is between your transmission and the tub. If you can rotate the friction material relatively easily, replace the clutch. You will have to take the transmission all the way out.
Jan 30, 2011 | Kenmore Washing Machines
I have a Whirlpool Ultimate Care II LSQ7533JQ1 washing machine. It agitates and drains but does not spin. I checked the motor coupling is not worn out nor broken. This is a two speed washing machine. ...
This is a neutral drain direct drive machine which drains the water first prior to spinning. After draining out the water completely, the motor pauses then restarts to spin the tub. It is possible that the problem is in the lid switch. If the motor is running during the spin cycle then the lid switch is good, otherwise it is indeed the problem.
The problem can be either in the brake particularly the cam driver or the clutch assembly. The clutch hub is attached to the spin pinion gear and as the spin pinion gear turns, the clutch hub also turns. The clutch lining is forced against the clutch hub by the clutch spring. As the clutch hub turns, friction between it and the clutch lining causes the clutch lining to turn. As the clutch turns, the tab that holds the clutch spring on the lining, contacts the brake cam driver, releasing the brake. The tab on the clutch lining remains in contact with the brake cam driver, holding the brake released and then providing power to the spin tube through the brake release.
The basket will not spin if the brake cam driver is broken because the brakes cannot be released. If the clutch spring is weak, the friction between the clutch hub and the clutch lining is not sufficient for the clutch tab to push the cam driver and release the brakes.
Check and replace, if necessary, the brake cam driver and the clutch assembly particularly the clutch spring and the clutch lining.
Dec 30, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Jan 30, 2010 | Whirlpool LSR7333 Top Load Washer
Tub does not spin. water pump works but no spin
  1. does the machine agitate? if no replace drive coupling between motor and transmission.If yes you have either a bad clutch or transmission.
  2. Remove cabinet and jump out lid switch to run with cabinet off.Put the machine in spin,look where the shaft goes up thru center of tub.Is the clutch drum turning?IF yes replace clutch.If not replace transmission.
  3. My guess bad coupling ,cost $20.
  4. Hope this helps .........Please rate my solution :)
Dec 14, 2009 | Kenmore Washing Machines
Will not drain and spin.
check to lid switch is working.
if so, then you will need to take the washer cover off, jumper the lid switch and washer the motor as it trasntions from agitiation to rinse/spin. If the motor is turning but the tub is not, then you have a clutch problem or gearbox problem. Some times the clutch gets greased up and starts to slip, inspect closely. This mean you will need to that the water pump off, motor to see the clutch
Jul 06, 2009 | GE Profile WPSR3120WWW
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
