Question about Hobart HL200-1STD Mixer
Is possible the repairing the magnetic circuit protection?
The fail this blocked the planetary with flour mix , after the planetary this repaired, now no function in the motor
    Scholar:
  • 109 Answers
It sounds like one of the interlocks is open. Probably the one for the safety cage.
Posted on Mar 23, 2014
Can't get the mixing paddle to come out. Directions say to turn off, tell head back, press beater upward turn left. Done this and still won't come off.
Try and get some CRC or similar into the connection so that it can get between the planetary driving shaft and the paddle. Elbow grease and muscle is what is going to free it up. Twist & turn until it frees up. Once you get it off polish up the shaft and scrape the hole clean with a knife or similar. There will be a black build up in the paddle hole. Flour gets in there and works itself into the alloy creating that black crust that locks the paddle onto the shaft.
Mar 23, 2018 | Food Mixers
Mixer won't start after mixing dough.
There is a good chance you burned up the electrical Connectors to the motor or you have have blown the FUSE that is located inside the housing. The Motor has a Self Shut Off when it overheats but if you have over taxed the motor more than once, then there is a good change you need to repair/replace it with something that can handle harder work. My sister got a Mix Master the same time I got my Kitchen Aid, My Kitchen Aid is running strong since 2003 and her Mix Master died in 2005 and I bought her a Kitchen Aid. Sorry but I am not fond of the Sunbeam Mixer's.... Quality has gone down hill over the years to keep their prices low.
Mar 01, 2014 | Sunbeam 2386 MixMaster Series Stand Mixer
Kp2671 stops and starts
It is not going to be a problem with the motor. It is going to be a chipped/damaged gear, a bent planetary center shaft pin, or possibly the planetary itself.
The first thing you need to do is take the mixer apart. You are going to have to clean of all of the gears and inspect them very closely. I recommend using paper towels and wd-40. If there is any damage, the gear will need to be replaced, in some cases the pin that sits between the worm follower gear and bevel gear can become bent, if it is, it also needs to be replaced. If all of the gears, bearings, and the pin are in perfect shape inspect your planetary assembly. In some cases the center shaft, which is pressed into the planetary can become loose, so it will still spin under no load, but as soon as you put something in the bowl it stops spinning.
Here is a link to the KitchenAid service manual. This will walk you through how to take the mixer apart, and put it back together: http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Please let me know if you have any questions, or need help with the repair.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Feb 15, 2013 | KitchenAid KSM103 Professional 5 Series...
A gasket type rubber ring is coming out of the assembly that the beater is attached to? it will not stay in place. where does it go? in the PLANETARY UNIT?
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Somehow the O-Ring is coming off of the Vertical Center Shaft (11)
That rubber ring prevents Oil from the transmission gears dripping down
to the Planetary into your mix.
Aug 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid gear- where the beaters are attached - comes out og mixer. Can place back and it works - but how do I fix permanently
Hi BEV, By the symptoms you are describing, it appears that your planetary/agitator shaft (where you attach the beaters) assembly is dropping from the mixer head, is that correct? When you replace the planetary and lift your bowl up into a ‘locked’ position, the planetary is being held in place by the beater resting on the bottom of your mixing bowl and ‘works’ for the time being. However, you don’t want operate your mixer that way for very long.
I suspect what caused the planetary/agitator shaft to drop from the mixer head is that one of the pins used to secure the planetary/agitator shaft assembly to the mixer head has failed (sheared) so now there is nothing holding the planetary/agitator to the mixer head. The good news is that this is fixable.
The inspection and troubleshooting of your mixer’s transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you are lacking one, you can download it from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM50PS. Unfortunately, entering your exact model number yields many Owners manual and no Parts Manuals, so I would use the following, KSM500, and select the last file under Parts List (16) KSM500WH0.pdf (857.41 KB). Verify your mixer matches the mixer in the illustrations. Turn to pages 4 & 5, titled ‘Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with a listing of all the parts. Make sure you inspect
Locate Illust. No. 14, Groove Pin, Part # 9795443. This pin retains the planetary/agitator shaft to the mixer head, and I suspect this is the pin that has failed and needs to be replaced. Getting to it will require the disassembly of the whole transmission. This will be messy as you will need to remove all the grease from the gears and center shaft.
While your mixer’s apart you should check for any other unseemly wear and tear on the gears, etc. You may find more things that need replacement than just the groove pin.
Besides needing a replacement pin and grease, you might consider replacing the gasket, too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Here’s a link to an excellent site for disassembling/fixing your KA Mixer. Although it’s a different model, the principles are the same: http://www.neilcrockett.com/mixer.htm and another link to a site that details the disassembly and replacement of mixer’s grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.htmltl
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! – hslincoln
Dec 06, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
How do i remove the planetary transmission cover off i need to pack the planetary and housing with grease i removed the surrounding nuts but the certer one im having a hard time with when i try to remove...
Get a pipe wrench and put it on the beater shaft,get a good bite on it.Grabe another pipe wrench and put it on the nut and turn ccw.I'm a hobart tech and repair these mixers alot,if your still having a hard time use a torch and heat the nut.Any ? let me know,can you please rate me.
Nov 22, 2009 | Hobart Food Mixers
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
Kitchenaid mixer mades a high pitch squeak when mixing
Take it to a local repair shop and they should be able to fix it in no time.
Jan 28, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Blakeslee CC-30 Planetary Mixer & dough hook not mixing correctly
it sounds like you may have a sheared key on one of the shafts.with no product in the mixer will it run in any other speeds?when mixing pizza dough you should only use 1st gear.if it does run in other speeds you have a sheared key or broken shaft,if it doesnt run in any speeds drop the planetary and check the key on that shaft.
Jan 05, 2008 | Food Mixers
Planetary attachment unit
Im a service tech for hobart.Is your problem with a mixer or scale?Whats the issue,i can help you.
Dec 10, 2007 | Food Mixers
Hobart HL200-1STD Mixer Logo
73 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
