Cord broke on finite audioworx headphones
I steped on my finite audioworx headphones and the cord pulled out and i opened it up and i can't find out to put it togetheR
5 Suggested Answers
SOURCE: broken starter cord to petrol generater
You have to tighten the spring inside where the cord goes. The pull cord pulls on leverage by using a clock like spring like a lawn mower. You have to take it all the way apart. The cord part. To get to the spring.
It is strange answering this in a computer section. I answer computer questions and this is certainly not a computer question. Unless you have a wind up computer. Now I have heard of these. Where are you located, if this is a wind up computer.
Posted on Jun 04, 2008
digritz
  • 530 Answers
SOURCE: the pull cord on my 110 honda broke, so we
It sounds like you have it back together correctly except for one issue. You did not put enough pre-load back in to the spring.
Or in other words you didn't rewind the spring enough.
Normally you attach the cord to be rewound and turn or tighten the spring until the length of the cord is completely retracted on to the pulley. This problem usually happens because the unit is reinstalled at this point. What you need to do is turn it another 2 to 4 turns (depending on the pulley size), to place enough tension on the cord to fully retract. You may have to experiment with the number of turns to get it right because both the length of the new cord and pulley size influence this.
If this still doesn't take care of the problem please let me know and I'll try and talk you through it.
Hope this helps.
Posted on Oct 07, 2009
  • 3074 Answers
SOURCE: I have a craftsman push
you will need to pull the shroud back off, turn shroud upside down, wind it up and with a screwdriver or another pair of hands thread the cord back through, tie a knot and burn it, let go of the it, it will wind the cord back in, pull on it a few times and make sure it is working, then reinstall. Hope this helped Tim
Posted on Mar 12, 2011
aquaman987
  • 927 Answers
SOURCE: MTD Yard Machine Model # 11A-084E029 Need help
Remove the recoil assembly from the mower, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Gary
Posted on Apr 30, 2011
Broken headphone cord
Mine did this too. Go to the skullcandy waranty page, and submit a claim and they will replace it for you
Jan 16, 2014 | Skullcandy SKDY Aviator Headphones White...
My skull candy ink'd left bud broke apart,how to re-wire it.
The wires inside the cord have broken, Unfortunately there is really no easy way to fix it, they don't solder well and replacing the cord is the only option but this also may not be successful. Replacing the headphones is the only proper solution
Mar 01, 2012 | Skull Candy Audio Players & Recorders
The part where the headphones plug in your computer and ipod broke off
Have a look at my Tip on Headphones, click my user name to find it. I can't say if it will help though, depending on the plug.
Mar 05, 2011 | Bose in-ear headphones - Black with...
Right ear bud isn't working
i have this problem too, except it's the left side that doesn't work. i think that's because the copper wire inside broke or is severed partly. there is no way to fix it... just go buy a new one and this time try to kot coil the cords around hour mp3or ipod.
Oct 27, 2009 | Bose on-ear TriPort Headphones
The pull cord broke , how do I put it back on?
You need to open up the pull cord assembly, and re-tie the remaining cord to the inside.
Oct 23, 2009 | Mtd Garden
Skull candies only work when i move the cord for a little bit
Sounds like one of the wires got pinched and broke. Check the wire for any spots where the insulation ripped open and tape them up with electrical tape and try it again. If that doesn't work you'll have to buy a new pair of headphones.
Mar 20, 2009 | Skull Candy Ink'd Stereo Ear Bud...
Right Bose In-ear cord separated from headphone
i know that these are very exspencive headphones, they were 100 dollars, and they are great. unfortunitally, these cannot be fixed without getting new headphones, sorry!!!
Mar 17, 2009 | Bose in-ear headphones - Black with...
Broken headphone jack
you should be able to get it out from the inside on the card. Do you have a sound card or is your sound on the motherboard?
Jan 27, 2009 | Dell Dimension 8200 PC Desktop
Acer Aspire 3620 laptop screen is coming off and goes black
sounds like a hardware problem....if u know how to assemble the laptop.it will be easy for u to fix that problem....all that things are connected to the mainboard..re insert all the cables what is loosen...regarding the headphone jack,if you have an extra jack you can replace that by resolder.
Jan 01, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
43 people viewed this question
 Grubhead
Grubhead
