Question about Channel Master CM-4046HD MODERNtenna Amplified indoor HDTV antenna
Cant describe it any better than I have. My antenna guy told me it is my tuner in my TV
  • Thomas Stauber
    Thomas Stauber Nov 18, 2014
    Hi Jennifer Miller, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Try it on another TV at the same location and see if it works. If it does than it's the TV. How far are you from the TV station??
    Master:
  • 423 Answers
Use an outdoor antenna with an amplifier or you can try to move the existing antenna closer to a window or at least move it to a location with a beterr signal,
Posted on Mar 12, 2015
Should i have a built in digital tuner
Your TV does have an inbuilt Tuner. You will need a Digital compatible Antenna. There is a big difference between digital and the old analog TV Antenna's
Hope this helps :)
Cheers Peter Smith
Apr 05, 2015 | Vizio VW32L 32 in. LCD HDTV
JVC HD-56G886 tuner stopped working
My (unfortunate) guess would be the Tuner received a static discharge when you were changing the antennas... this time of the year is bad for static - if you're in a "Winter" climate.
Receivers have a very sensitive FET or MMIC amplifier right inside from the antenna connection to make it better for picking up distant stations.
However, this same "sensitive" amplifier is also prone to being destroyed by even a small static discharge... especially if the tuner had its power turned ON.
Sad to say, it's likely toasted... :-(
(I hope I'm wrong... but you have already tried all other possible solutions)
Jan 12, 2013 | JVC HD-56G886 56" Rear Projection HDTV
Durabrand 13' DU1301 TV problem: I can barely see the picture or hear anything because of intermittant snow. Sometimes the picture will roll as if we are back in the 70s. When I turned the tv on its...
Hello
The fault you describes is due to low signal strength. If tuner of the said TV is faulty, this type of snow interference will occur too. Just check for good firm connection to its antenna terminal. If it is Ok, check the continuity of the cable used with antenna. Check the orientation of yagi antenna if used outside. If all are OK, and nothing help you, just replace its tuner with same type and number. Tuner is a small metal box type component can be seen soldered directly to the main printed circuit board inside. Usullay, its one terminal will come out as antenna IN of the TV, to which you connects the external antenna or cable. You must have a concept of soldering and desoldering to replace it, and must have a knoledge in electronics too. OK.
Jul 29, 2011 | Durabrand DU1301 TV
Hi - i purchased an in car TVTATSC Digital Tuner - I assume, from Alpine. The installer has it connected to a - admittedly temporary - antannae that rests on my roof, above my back windshield. PROBLEM - i...
to date, there is NO TV tuner or antenna that will allow reception adequately while vehicle is in motion. Whoever told yu otherwise is ill informed or blowing smoke. Never has been such a beast. It is designed for car viewing while stopped/parked again in the right orientation to the onboard antenna. But higher end dipole aantennas do get more stations and better signals than the self included ones that come with some of thes tuners.
Good luck
A Sat box and accompanying $3k+ disk roof top car antenna is another story with a subscription like Directv. This will give yu Tv in motion.
Sep 08, 2009 | XO Vision XT-5000N High Sensitivity Car Tv...
Grundig PVR/ Digital TV Tuner with no external antenna?
i am living in a house where i cant place an external antina. is there any reveiver that donot require exteernal antina and we can receive channens
Jun 27, 2009 | Televison & Video
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Mitsubishi vs-50603 does'nt get regular antenna chanels.
Indoor antennas have very limited capabilities especially in areas with elevation changes and heavy tree cover. Ideally, you should put an outdoor antenna on your roof or the highest elevation you can find with a relatively short distance to the TV. Make sure it has a good UHF section as this is where all digital broadcasts will be sent by the broadcasters as the digital transition occurs. You might try an amplified indoor antenna for better results than what you have now, but its no substitute for an outdoor antenna.
michtech
Feb 16, 2009 | Mitsubishi VS-50603 50" Rear Projection...
No TV Reception
Sony Technician confirmed that that the TV has an analog tuner
2 options - outdoor antenna with digital converter --- or cable service
Jan 16, 2009 | Sony KP-53V75 53" Rear Projection...
Digital to Analog converter...no signal
One of the problems with digital reception is if the signal is not strong enough for the converter box/or built in tuner on a new TV- you will not get any picture at all. If you followed all the directions-and the converter box shows no channels- then you do need a better antenna. I don't know how far you are from the broadcast antenna, but a good rule of thumb is if you live 10 miles away, buy an antenna that is good for twice that distance, or further. They are rated in miles of reception
Jun 23, 2008 | Televison & Video
Channel
make sure that ur antenna/catv is properly connected to antenna/catv input of ur tv...better check the center lead if ur using coaxial cable..then try to reprogram/autoprogram ur set.
navigate also on tuner settings...via remote..
if u get nothin after autoprogram..probably bad tuner in ur set..u need a prof tech to fix it...thanks hope this help
Feb 05, 2008 | RCA TruFlat 27F520T 27" TV
Channel Master CM-4046HD MODERNtenna Amplified indoor HDTV antenna Logo
719 people viewed this question
Top Channel Master Electronics - Others Experts
Are you a Channel Master Electronics - Other Expert? Answer questions, earn points and help others
