My samsung sw75v9w diamond drum seems really loose, when it goes through the wash cycle and spins a little every 1-2 secs it seems to be banging the side of the machine. Is there anything I can do to fix this myself?
  • 156 Answers
SOURCE: thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Posted on Feb 25, 2008
SOURCE: Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Posted on Jul 15, 2008
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
onthejob5130
  • 640 Answers
SOURCE: spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Posted on Feb 07, 2009
SOURCE: my washing machine bangs terribly
Check under the washing machine to see if there is any grey dust. My machine made so much noise on the spin that i could not use it. The solution was the front brick had loose bolts. When I tightened them up, I had no more problems
Posted on Apr 09, 2009
My Hoover 750L starts its spin cycle but when goes to a really high spin it makes a noise.
Check your mounts and support springs---one of them maybe broke or loose---since you haven't described the noise this is the best i can come up with. GL
Sep 18, 2017 | Hoover Washing Machines
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Samsung SW75V9W spin
Please be specific, if there is no spin check the motor and voltage when the spin cycle starts, if there is no voltage then the controller is a suspect.
If the spin RPM is low then check the drive and reset for easing the friction.
Click on : bearings
Jan 23, 2013 | Samsung Washing Machines
Starts Banging really ******* spin cycle, then quits... seems like the drum is loose.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 12, 2011 | Frigidaire GLTR1670A Front Load Washer
Loose drum bangs during spin cycle turn by hand with nothing in drum and still bangs?
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
Jan 25, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Banging noise on spin cycle
My beko washing machine was making a racket like this. What it was was the large blocks of concrete bolted to the drum had come loose. Solution was to get a 13mm socket with a bar and extension and tighten them up really hard as far as I could manage. THen the probelm dissapeared no more banging. Worth a try if your has similar blocks attached to outer drum
May 09, 2009 | Washing Machines
Spin cycle very loud,
Feb 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The drum bangs on the spin
Two possibles for this are aloose balance block or cracked drum spider.The front block is most prone to coming loose.
To check spider rotate drum little by little and pull towards you to check for movement.
Post back if further help needed.
Thankyou
Dec 19, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
