Question about Seagate Momentus 5400.4 250GB SATA/300 5400RPM 8MB 2.5 Hard Drive
Cant restore raw hard disk - Seagate Momentus 5400.4 250GB SATA/300 5400RPM 8MB 2.5 Hard Drive
Need restore my RAW file system back to NTFS without losing any hard drive files?
Still don't know what you can do to rescue your lost drive files right now?
OK! I have ever followed a video tutorial to resolve solve such hard drive data loss problems from here:
https://www.youtube.com/watch?v=S1F72QPGHm8
You can also check it and follow its steps to see whether all your files could be restored successfully.
In the future, to avoid such data loss troubles, always regularly save your drive stuffs on several places, not only on one hard drive.
Nov 07, 2014 | Seagate Computers & Internet
When I look in disk manager it shows my external hard drive is in raw
DO NOT FORMAT YOUR DISK. It has been damaged; how easy or even possible to recover your data depends on the degree of damage.
Try your HD in another computer; if it works, make a back-up of your files on another disk.
To understand what RAW format means, try this
http://www.ehow.com/facts_7167186_raw-disk-format_.html
or look for it in Wikipedia.
By searching the internet ("raw disk has data on it"), the first article I found was this
http://html5.litten.com/how-to-fix-external-disk-drive-suddenly-became-raw/
which may be of some help.
In that article a Linux system is used to read and modify the disk. There other tools for repairing this type of fault, for example, http://www.easeus.com/resource/recover-raw-disk.htm
(I do not know if this free:: the information in the article is certainly free though)
Recovering your files will probably mean a lot reading, research and time, but you might be lucky. I recommend reading any article you are going to use through to the end before you start with it.
25.April.2014
Mar 03, 2014 | Computers & Internet
My hard drive is asking to format how can i retrieve my data
Save what data you can to a different hard drive then format the unit . When finished reinstall the data from the drive to which you save the data
Feb 25, 2013 | Samsung Computers & Internet
Hard Drive RAW System
Run diagnostics on the drive it may be failing. If it's ok you can try to reformat it from Windows Disk Management.
Or if you need to recover data for remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 11, 2012 | FireLite (USBFLB80) Hard Drive
Formating raw usb flash disk
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 20, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My usb flashdisk become raw data
1). Do not format this hard drive before you've recovered all your stored data back. In your case, the formatting process may erase everything on your drive and make your data gone permanently.
2). Never save anything new on this drive in case that any new file would rewrite your original data.
3). Plunge this drive to your computer and download a RAW drive data recovery freeware to get back all your lost data back:
http://www.freeware-fix.blogspot.com/2013/02/raw-hard-drive-recovery.html
This hard drive has helped many people around me restore their inaccessible data back from a RAW drive or memory card. It can also work perfectly on your drive.
Read more detailed information of this freeware here:
http://blog4mark.blogspot.com/2012/10/help-external-drive-became-raw.html
4). Save and back up all your restored data on another drive in case of data recovery failure.
5). Format this drive to see whether it is fixable.
Dec 16, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Seagate Momentus 5400.4 250GB SATA/300 5400RPM 8MB 2.5 Hard Drive Logo
16 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
