Question about Ovens
Electrolux Chef upright gas fan-forced oven that doesn't heat up over 150 degrees celsius
We have an Electrolux Chef upright fan-forced oven that uses natural gas. It is model number GSC6638SNG.The oven doesn't heat up over 150 degrees Celsius. Technicians have replaced the burner and valve but it is still not heating up properly. The top front edge of the oven gets very hot while the oven is running and it seems to be blowing a lot of hot air the vent above the grill. Any advice on what we should replace next?
vest6
  • 196 Answers
SOURCE: smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Posted on Jan 26, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: smeg oven
    Sounds like you need a new oven element fitting.
    Posted on Dec 08, 2008
    • 57 Answers
    SOURCE: Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
    u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
    Posted on Jun 27, 2009
    garing
    • 998 Answers
    SOURCE: My Magic Chef 21MS Natural Gas Oven will not heat
    glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
    Posted on Aug 25, 2009
    Whirlpool oven will only get to 250 degrees, help
    250' Centigrade is full power, Gas Mark 9, 482' Fahrenheit
    This is an approximate conversion chart between gas mark and electric ovens. This information was copied from the rec.food.cooking FAQ.
    Gas Mark Fahrenheit Celsius Description 1/4 225 110 Very cool/very slow 1/2 250 130 --- 1 275 140 cool 2 300 150 --- 3 325 170 very moderate 4 350 180 moderate 5 375 190 --- 6 400 200 moderately hot 7 425 220 hot 8 450 230 --- 9 475 240 very hot
    Sep 24, 2015 | Whirlpool Ovens
    My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
    The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
    Dec 26, 2014 | Magic Chef Ovens
    How do I clean the electrolux oven? It won't start after i take the racks out
    As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
    Dado
    Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
    Oven temperature sensor
    The Electrolux ovens usually used PTC thermistor PT500.
    Resistance of PTC sensor depending on ambient temperature and should be around 550 ohms on ambient temperatures between 20-30 Celsius. I would like to check insulation rasistance between metalic housing and each connection terminal. The rasistance should be higher than 2 MOhms.
    Dado
    Jun 30, 2014 | Electrolux Ovens
    Don't know how will the chef premier fan forced grill work please help thanx neha
    The fan radiates the heat to the food to be cooked in the steady heat . when the heat is modest the fan does the convecction well to keep all the areas well heated.
    So use only the required heat and the best timing
    Sep 11, 2010 | Ovens
    Jun 27, 2009 | Ovens
    Magic chef oven/stove top range not staying hot
    Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
    Please let me know if I can assit you further.
    Vic
    Jun 20, 2009 | GE JGRP17 Gas Single Oven
    Ovens Logo
    15 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
