Question about Makita Drills
Circular saw 5900 gear - Makita Drills
    Champion:
  • 304 Answers
Try oasistools.com
Posted on May 04, 2014
How to gear spindle from housing
The unit is retained by two or three screws surrounding a retaining ring on the saw blade side, and I believe there are some screws holding the gear housing on the motor side that need to be removed as well. I just replaced the bearing on mine a week ago, and even though the situation is obvious once you figure it out I was not smart enough to do so, and wasted an hour trying to figure out how to remove that retaining ring over the bearing. Good luck
Apr 05, 2013 | Makita 5007MG Factory Reconditioned 7 14...
Saw stops when i start cutting 1/2 plywood.
If it actually binds and stops the motor...... it sounds like the motor is bad, the bearings are bad, or the blade is on backwards. If the motor keeps spinning, but the blade stops then the gears are bad or the blade bolt is not tight.
Dec 10, 2012 | Worx Versacut Mini Circular Saw
What kind of oil do I put in?
They sell tubes of oil for the saws. If you can't find it You can probably use 90weight gear oil. the stuff in the tube smells about the same.
Sep 05, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
Motor runs, saw not cutting
Hi
If motor is running and the blade is not turnning the motor pinion gear is damage.
Go see this link for parts diagram.
http://www.ereplacementparts.com/skil-5500-f012550000-714-circular-saw-parts-c-130_160_843.html
Feb 07, 2011 | Skil 5500 01 7 1/4" 120V Circular Saw Kit...
I have a Porter Cable 345 6" saw "3" series. Do I need to oil this baby?
unless it has a gearbox with a plug, no. the bearing are sealed. where the saw breaks down the middle, the metal part from the plastic part, there is grease in that gear compartment.
Jul 11, 2010 | Porter Cable 345 6" Circular Saw Saw Boss
For the Skil 77 worm drive circular saws what type of oil is required?
Use 90 weight gear/differential oil but if you use it outside in the cold weather it's too thick, use 40 weight oil then and switch to the 90 weight in the summer.
Jun 03, 2010 | Saws
B&D Corded Circular Saw - Arbor Does Not Move
This model is not equipped with a clutch so its possible that the gears are stripped, shaft broken. If the blade moves freely then this is probably the case. If blade does not move freely, check for any foreign objects between blade and blade housing. I hope this has helped if you have any further questions don't hesitate to ask. Please rate on the helpfulness of the answer. Good Luck and have a great weekend.
Apr 04, 2010 | Black & Decker CS1012 7-1/4" 12 Amp...
What are gears?
circular saws dont have gears mate,they normaly hace belts to adjust the rpm(reveloutions per minute) normally between 4500-6000rpm.the denser the material the faster the speed required.
Sep 13, 2009 | Dewalt DW715 Heavy Duty 12" Single -...
Drills Logo
27 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
