Question about Electrolux Ovens
Chef electrolux oven won't heat up
We have an Electrolux Chef upright fan-forced oven that uses natural gas. It is model number GSC6638SNG.The oven doesn't heat up over 150 degrees Celsius. Technicians have replaced the burner and valve but it is still not heating up properly. The top front edge of the oven gets very hot while the oven is running and it seems to be blowing a lot of hot air the vent above the grill. Any advice on what we should replace next?
vest6
  • 196 Answers
SOURCE: smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Posted on Jan 26, 2008
barkencoa
  • 3463 Answers
SOURCE: smeg oven
Sounds like you need a new oven element fitting.
Posted on Dec 08, 2008
garing
  • 998 Answers
SOURCE: My Magic Chef 21MS Natural Gas Oven will not heat
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Posted on Aug 25, 2009
barkencoa
  • 3463 Answers
SOURCE: electrolux fan oven. Have replaced the
If the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Posted on Sep 15, 2009
Testimonial: "Ok will try that, but is the elemant at the top of the oven not the same one that heats up the grill? If so the grill heats up fine. "
rylee_smith
  • 8619 Answers
SOURCE: converting fromTown Gas to LPG in gas cylinders
Hi
Thanks for using FixYa. If your range/oven doesn't seem to work at all, check these:
Fuse/circuit breaker
Check to see if power is getting to the range/oven. If even a light won’t turn on then check for a blown fuse or tripped circuit breaker.
Main wiring
Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 15, 2010
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
I'm looking for classic chef wall oven manual please help
The manual is here
Page 1 Operating and Installation Instructions Electric Classic Wall ...
https://product.electrolux.com.au/Public/File/?Id=14896The Chef Classic oven is a compact wall oven or under bench oven and is available in the following models. Conventional oven with 90 minute ringer timer.
classic chef wall oven manual Google Search
Nov 22, 2017 | Ovens
Electrolux chef oven.. pilot light on but the oven is not heating up
I need more information to help you, first of all, to the bast of my knowledge I thought all there units were light but ignitors not pilots. I need a model number to verify. Also if the ignitor comes on just because it glows does not mean it is strong enough to open the safety valve and allow gas to enter the burner. I use a meter to determine that issue, it needs to be 3.2 to 3.6 amps to open, if ignitor is running at 2.8 amps it may work sometimes, if lower, it won't work at all just glow.
I would need a model number to get you more information, looking forward to assisting you further...
Jul 15, 2011 | Ovens
Hi. My oven stopped getting hot (elements still get barely warm) right after the temperature sensor broke off. Could the broken sensor cause this? Thanks.
yes it can and ur element is probably bad shut off power take out 2 screws on side of it n pull ito ut to disconnect wires n put new one in !!
Apr 07, 2011 | Ovens
I need instructions for chef condor convection oven-having trouble with timer
i have a chef condor wall oven and the door wont shut properly as the latches have gone loose or broken
Jun 09, 2010 | Electrolux Ovens
Oven gasket for Chef Select model EWOSLFMW
Bought one online from Big Warehouse Sales
Jan 09, 2010 | Electrolux Ovens
My Magic Chef 21MS Natural Gas Oven will not heat up in oven. The top burners are fine.
Aug 25, 2009 | Magic Chef 9122 Gas Single Oven
Ovens Logo
14 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
