I first looked at the playback thru the eyepiece and there was a line across the picture that looked like a crack in a mirror. I opened up the viewer to see if I could find anything. The small strip that looks like tape with wires in it looked damaged. When I re-assembled it, I got no picture at all. Can I get a new eyepiece assembly or the tape strip to fix the problem?
SOURCE: color is splitting, and almost looks 3D.
the ITC222A convergence option missing repair kit at the following link should repair that issue. The kit contains the parts and the instructions on CD
http://www.tvrepairworld.com/
SOURCE: Fixing RCA TV Model R52WM24YX61 with rainbows
The ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com should solve that issue. Instructions are included.
SOURCE: I have a projection tv that the pictures ghost and
You have a convergence problem. I have a tip which explains what this is, how to repair it and where to get the parts at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics . Let me know if this is not the problem or you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
SOURCE: Blue, red and green lines
This RCA tv model have a convergence fuse.The FL 231 convergence fuse dead.U have a soldering iron and can do basic soldering?Try Ebay.com to buy the convergence fuse.The FL231 three fuses the one in the middle is dead.The FBT,the big black block of plastic,resolder that too.
SOURCE: Picture is bowed inward and looks like a 3d image
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
