My broadband provider has provided me with a broadband system which comes from an antenna on the roof, into a small plastic "base unit" with an RJ45 cable, out of that with another RJ45 cable and into my Tower P.C or laptop and the internet work fine. As soon as I tried to connect the RJ45 from my laptop into the WAN port of the Br-6504n router and connect the laptop to the router through thr router lan port all the trouble started. The internet connection was lost. At the start I was able to connect to the router, now i cannot do that anymore. The I.P adresses all seem to be the same after I connect the router, and the laptop is not able to diagnose the issue. The most recent error was that it attempted to ping the DNS, which had the same number as the IP address but did not get a response. My reason for buying the router was to connect my Tower P.C wired into the router, and the router to be connected wirelessly to the laptop. Some friends have mentioned a wireless access point was the solution. Is there some way of using what I have to fix the problem?
First you need to determine if your broadband provider permits you to connect a router to the system. Second you need to get his instructions for changes required in the equipment he provided to make this possible. To have any possibility of assisting you further I would need information as to the broadband provider's website and the ability to find the necessary data there.
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
I have a list of Emoticon & Smiley codes. When using the keys for these codes, no icons...
(More)
I have a list of Emoticon & Smiley codes. When using the keys for these codes, no icons appear (just shows the code). What am I doing wrong? I'm using Microsoft Windows XP, and I'm on Yahoo.
I do not get a connection trying to set up my newly purchase Samsung HT DB 1250 Home theater system....
(More)
I do not get a connection trying to set up my newly purchase Samsung HT DB 1250 Home theater system. It does not get gateway ping?
