Question about EdgeStar Heating & Cooling
Can the freon in an edge star. Portable air conditioner be refilled?
It is no longer cooling well. Sounds like the compressor tries to come on
SOURCE: Maytag NMPEB08F2A Portable Air Conditioner
I have the same problem w/ a window unit - fedders unit under the Maytag brand. No idea how to fix it, but would be great to get some info on this.
Posted on Aug 05, 2007
bobotfel
  • 236 Answers
SOURCE: Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Posted on Dec 31, 2007
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
  • 5 Answers
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Posted on Aug 03, 2009
SOURCE: need any user and -or service manual for delonghi PAC -75 U
Here is the manual
http://www.appliancefactoryparts.com/content/pdfs/123150.pdf
Posted on Jun 29, 2010
I have a TCL TAC-09CP/C portable air conditioner, working, clean. Everything looks fine but it does not cool. I was wandering If I need to refill the cooling gas. Is it possible? What can I do?
Find out if the thermostat is turning the compressor on first. The compressor has a capacitor that can go bad. Freon leak is possible but unlikely unless the coils in the back have been damaged by something sharp.
Sep 14, 2017 | Heating & Cooling
How do i add refrigerant to a amcor kf900e portable air conditioner"
The compressor picks up the gas that is bringing the heat removed from the house to be compressed to liquid and cooled in the condenser coil When running the compressor is very hot. When the freon is low the compressor will be cooler because it doesn't have as much heat to compress. To add freon you must add a service valve to the low pressure line.
Aug 02, 2014 | Amcor KF 9000 BTU Silver Portable Air...
Ac not cooling
Take it to a dealer/licensed repairman. They are allowed to drain and refill your compressor with new freon.
Mar 12, 2012 | Maytag Portable Air Conditioner M6P09S2A
Sunbeam portable air condition..all things work..compressor runs..but now cold air sunbeam portable air conditoner mode KY25 ..9,000 btu I have it since 2005..I've used it for one year..it's been...
sometimes storing an AC for long periods of time will allow the coolant that it uses to seep out, leaving you with an AC that seems to work, but won'tr cool any air. If you have a user's manual (or can find one) check to see what type of coolant it uses (if it's freon or something else) and if you can refill it. If you can refill the coolant, that should resolve your problem ... if not, you might be able to take it to a repair shop and have them do it for you. Good luck!
May 29, 2011 | Sunbeam SCA082RPC1 Portable Air...
The compressor light is on but the air is NOT cooling
dear sir
please make sure first your air conditioner,s compressor is working, for know that try to hear compressor sound and test by a meter check current consummation if it more than to 5 ampere then it,s mean compressor is working. and if compressor is working and unit not getting cold then it can be leakage in system .need to refill freon.
hope answer the question
thank you
please vote!
Sep 30, 2010 | Amcor V22253 Portable Air Conditioner
I have an AMCOR 1400E and my compressor kicks on and gets very hot but no cold are comes out of the unit, I think i may have a bad compressor and don?t know who to call about the warranty since amcor is...
dear sir
if your aircon compressor is working and it,s not getting cold then it can be cause of leakage in aircon system then need to refill freon on your system .
please contact to your area amcor dealer for get the benefit of your warranty period(if it is in under warranty)
thank you
Aug 30, 2010 | Amcor PLM-14000E Portable Air Conditioner
My GE portable a/c will cool when I first turn it on. The compressor kicks on and it cools fine, but after it runs a few minutes it kicks off and never cools again. The fan just runs. It does not appear...
I would say that if it starts cooling when it's turned on, then it has freon in it. Sounds more like it's kicking off on high head pressure, meaning the condenser is not getting cooled, head pressure builds up then a safety limit switch shuts it down to save the compressor from burning out.. Is there a condenser fan maybe not operating? or are the condenser coils clogged up with dirt?
Jul 15, 2010 | General Electric APE08AK Portable Air...
I have a Maytag portable air conditioner (about 5
when the compressor shuts off most of the freon goes to low side(cold) when it starts..it has a lot of freon to move and it works hard and you hear it loud after it has moved most of the freon over to the high side,the sound is less so not to worry it's normal if it clicks when it starts then you worry
9
Aug 20, 2009 | Heating & Cooling
Heating & Cooling Logo
99 people viewed this question
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
