Question about Coby TFTV3227 32 in. LCD TV
Remote not working
My remote will no longer work- I have changed the batteries- I have also tried two separate "universal" remotes- Neither of those will work- Now I have two problems- First I would like to have a working remote but in addition my cable provider has rearranged the channels- I cannot seem to figure out how to get to the place to reset the channels without using the remote- So I no longer am able to watch 6 of my favorite channels-
5 Suggested Answers
  • 133 Answers
SOURCE: can I use a universal remote on a coby 7
No you cant, coby has no universal remote codes
Posted on Jun 04, 2010
  • 8457 Answers
SOURCE: Hi I have a brand
The codes that was in ur universal remote manual don't work,useally there are no more codes out there will.Try website like Remotes.com to buy an original remote.
Posted on Dec 17, 2010
  • 82 Answers
SOURCE: I can not change the
there is some problem with the switches in your tv my dear....
plz call to the required service center.........
Posted on Jan 22, 2011
  • 3 Answers
SOURCE: is there a universal remote that will work with a COBY TFTV 1904 Television?
some times in the manual for the universal, it will have a way to find the code, manually, by holding down certain buttons and watching for light to flash or tv will turn off or on.. It took me almost 1 hour once but my patience finally paid off. :) Just thought you might want to try that..
Posted on Jul 19, 2012
I have a Sanyo DP42849 TV and the original remote but when I changed the batteries in remote it no longer works. I have tried several new batteries. The lights work on remote but not functioning the...
A lot of the new televisions today come with remotes that have to be re-programmed after the batteries are changed. I would contact the television's manufacture and find out if the re-mote, the television, or both have to be re-programmed.
May 15, 2014 | Televison & Video
Remote no longer works despite changing battery, are replacement remotes available?
Usually you can buy replacement remotes, or you can buy a universal remote. What product are you trying to replace the remote too? A bit more detail and we can help better.
Oct 15, 2013 | NORTHERN INTERNATIONAL INC Essential Home...
Sanyo 50" Plasma DP50710 Remote will not work.
Try to synchronize the remote control with an other code to your TV brand.
Jan 23, 2013 | Sanyo Televison & Video
Universal Remote: UR5U-8780L - Not Working and CBL Button Constantly Lit
press cable and record buttons at the same time and wait for all the lights to flash in sequence then let go. this will reset remote to factory defaults. then reprogram remote with codes for each device.here is a site for codes. http://www.universalremote.com/resources/pdfs/UR5U-8780L_UR5U-8790L.pdf
May 25, 2012 | Universal Remote Control Televison & Video
When we press any button, all we get is the the red light on top left side of remote light up. channnels will not change, volume not change, won't power on or off. how can we fix this.
Sorry but without knowing the particular model number of the remote control or indeed whether or not it is a philips universal remote control, I can't give you a definative answer to your problem. I recomend however, if you haven't changed the batteries in your remote that you put new one's in as the batteries maybe too weak to operate the remote fully, this will at least eliminate this possibility. If you are using using a Philips universal remote control then try resetting the remote using the correct code for machine, if you don't know the code then try the Philips support website for the code for your tv. After that I would consider that either the remote or the machine has developed a fault where the remote's I/R no longer transmits or the machine's I/R receiver no longer works. Personally I would purchase a cheap / middle of the range universal remote and try that to see if that works as it is a much cheaper option than having the machine looked at by a technician. If you would rather there are online sites where you can by genuine remotes for most tv's etc but obviously this is a more expensive option than a universal replacement.
Hope this helps,
James
Apr 25, 2010 | Philips Televison & Video
My remote 00053a no longer works my tv
I assume that you tried replacing with fresh batteries, the battery contacts are clean?
Universal remotes are available to replace yours. You have to type in a product code for the type of TV.
Feb 05, 2010 | Samsung TV Remote Control
Remote control no longer works
buy a new one,,,(universal remote control)
Jan 30, 2010 | JVC HR-XV1 DVD Player/VCR
Remote will no longer work
Your best bet is to buy a universal remote that would work with your model television or a replacement remote from your manufacturer.
This one is pretty cheap (and may be your exact remote?)
http://www.replacementremotes.com/store/productdetailp.cfm?productid=28946
You could probably buy a universal remote cheaper at walmart or target, but the cost savings will cost you the time and hassle to program the remote (and if you buy a universal, you must make sure it works with emerson TVs).
May 12, 2008 | Emerson EWF2703 27" TV
Remote No Longer Works
It appears the remote sensor in the Television itself has stopped working. If the TV is still under warranty I would try to contact the manufacturer to see what they can do for you. Can you still change channels manually? If so, this is most likely the case.
Dec 29, 2007 | Philips Magnavox 27MS343S 27" TV
Coby TFTV3227 32 in. LCD TV Logo
16 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
