Question about Westinghouse Dishwashers
I have a Westinghouse wdf901. There are no lights except when I hold button lock and program together and then only the 65 light comes on
First time it's had a problem. It's about 5 years old
SOURCE: dishwasher not emptying
No solution as yet, will most likely replace the dishwasher.
Posted on May 31, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Have a kitchenaid dishwasher KUDS25SHWH1 - the
Unplug the unit for 15 minutes then plug it back in. This should reset all your computer system and make everything work again
Posted on May 28, 2009
  • 177 Answers
SOURCE: Lock light stays on
It sounds like the circuit bontrol board is cracked or shorted, which means it must be replaced.
Posted on Jul 24, 2009
  • 69 Answers
SOURCE: "Light Dry" light flashes 5 times & odd light displayed
maytag website...all the help youll need
Posted on Sep 20, 2009
  • 180 Answers
SOURCE: kleenmaid dishwasher wont run, all lights on at same time
Check the door switch.
Posted on Oct 25, 2009
Is there a reset button on frigidaire dishwasher model fdb710lcb0
Mate im in Australia and don't know if the Frigidaite is the same as the Electrolux/Westinghouse but you can try this I posted a day ago:
On the Westinghouse and Electrolux dishwashers to reset a program that it defaults too you start the program and once initialised then press and hold the program button for about 3-5 secs. The panel will beep and all the lights will come on and not flash. From there on using the program button you select the wash cycle you want
May 28, 2016 | Frigidaire Dishwashers
Security light flashes and it won't start
top
CODE ALARM SYSTEM
information is always subject to change and correction Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm only Press the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter “UNLOCK” button once OR turn the ignition switch to the “ON” position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button
Press lock (left) button the remotes to be programmed. The door locks will cycle one time.
Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
top
Jul 10, 2008 | 1996 Subaru Legacy
How do i reset the consol?
already answered as solution to another question by you.
May 03, 2014 | Westinghouse Dishwashers
I can get my dishnetwork remote to program for the volume nor to turn it on or off help me please the model #w32001
We would be happy to help you with that.
Step 1:
Press and hold the TV button until all mode button back lights come on, then release.
Step 2:
Use the number buttons to enter the device code corresponding to your Westinghouse TV. Potential codes for White Westinghouse are: 500, 719, 664, 555, 674, 659, 670, 672, 641 and 573. Then press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. Your DISH Network remote should be able to control your TV. Thanks for being a valued DISH Network customer.
Phillip Chang
DISH Network Customer Service Representative
Jan 20, 2011 | Westinghouse W32001 20 in. HD-Ready LCD...
I somehow locked the buttons on my F11 Polar watch but I cant seem to unlock it???
By pressing and holding the Light button, you can:
Lock and unlock all the buttons, except the
Light button, in the Time of Day display or while
recording your exercise. Press and hold the Light
button until Buttons Locked or Unlocked is
displayed.
Sep 23, 2010 | Watches
Lock light stays on
Jul 24, 2009 | Kenmore 15762 Dishwasher
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Door Lock light Flashing
IF this is the A WMA model then im affraid to say that you have blown your program board.. This depending on the extent on the damage can be repaired but 7 times out of 10 it usually is not...
if you was to remove the front pannel by unscrewing the screws around the soap draw section... and remove the panel.... then detach the board from panel you will c where the largest plug is connected to the board that its is blown.....
P..S Removing the top cover makes removing the front panel a lot easier... The screws are near the front on the sides....behind the little clips
Nov 12, 2007 | Hotpoint WMA35 Front Load Washer
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Dishwashers Logo
29 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Tom Chichester
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
