Question about Fisher and Paykel Washing Machines
I have one broken suspension strut on my Fisher and Paykel. I want to replace myself but do not know how. I checked youtube but there are not any videos on this
  • Fisher and P... Expert
  • 554 Answers
Get one out of another machine,They are the same size.
but not AquaSmart as they are completely different suspension rods.
remove two screws under the lid bump stop at the front of machine
lift up panel to see the suspension rods.
Posted on Apr 21, 2014
  • 96 Answers
SOURCE: fisher & paykel smart drive washing machine leaking water
If your washer is still under warranty, I would call the company and have them send someone down. If the leak is from either the drum itself or a seal then I don't think you could handle it yourself. But, first make absolutely sure that it's not from any hose connection. Tighten all the connections, especially those to the drain pump. And check the pump itself for any leaks.
Posted on Mar 02, 2008
ngfam1
  • 639 Answers
SOURCE: Washing Machine Broken
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
  • 93 Answers
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Posted on Jul 10, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher and Paykel Kelvinator Washingmachine All lights on n
too many clothes in the washer maybe
hows about a F&P manual?Gimme a dollar LOL!
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
How to clean drum in fisher paykel washing machine ? Also why so noisy and moving across floor on spin cycle?
bowl out of balance
bowl not level
check for suspension bolts and insulators holding the bowl level
Jul 18, 2016 | Fisher and Paykel Washing Machines
Out of balance
Have you replaced the suspension damper rods on the machine
these also need replacing at the same time.
Jun 13, 2013 | Fisher and Paykel Washing Machines
How to fix my fisher & paykel washer machine from shaking and knocking
Your 4 suspension rods will need replacing as they are loose & worn.
Or the bowl has lost its ballast water from the top & bottom balance rings of the bowl.
Jan 05, 2013 | Fisher Paykel WA42T26GW1 EcoSmart 25" Top...
Fisher and paykel smart drive 5.5 toploader drum springs have broken.. how do I fix this?
These parts are suspension damper rods all the same size in 5.6.7.and 8kg machines.
But no AquaSmart machines as these are different.
May 10, 2012 | Fisher and Paykel Washing Machines
Gw708u spin cycle wont work
There are 3 common causes of this, 1: OOB (out of balance)switch is faulty - to get to this you must remove the display console cover and the main control module and it is underneath in (common microswitch, test with a multimeter) 2. Lid Reed Switch has failed (Bridge out red and black wires in 4 wire plug on right side of motor controller module to test- machine will spin when you select spin cycle when this is bridged if this is the issue) 3. Broken Balance spring (simple but common - left front corner of machine attached to neck ring on top of drum and to the suspension strut: you can bend the end of a broken spring to re-attach)
I hope you can make sense of these instructions. i am better at doing than telling
Oct 25, 2010 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine becomes
i think that 1 or more suspension rods r faulty. lift the lid and at the front of the machine u will see 2 plastic covers, remove the covers and undo the screws underneath. now lift the front of the hob up gently and u will see the suspension rods. they r easliy replaced. but first see if they havent just popped out. if they have just popped out look at the other 3 and refit to how the others are.if u need more help or u find another problem reply back and i will help u more.good luck
Apr 20, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Tub is crooked
sounds like 1 suspension rod is broken . undo 2 screws at front under lid to lift top hob up. do not lift it too high.look at which side is lower to see if suspension rod is faulty. if suspension rod is faulty replace it. please reply if u need more help. turn power off b4 u work on it dont want any accidents. good luck
Mar 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
109 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
