Maytag commercial washer the error f21 is not clear
I HAVE MAYTAG COMMERCIAL WASHER MACHINE MODEL.MAH22PRBWW0 F21 ERROR IS NOT CLEAR
jsrock516
  • 5911 Answers
SOURCE: Whirlpool duet washer F21 error code. Just bought
"F21" is a Long Drain error. The following link explains how to torubleshoot:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
What this usually means is that you have something clogged in the drain pump and it needs to be cleaned out. In the majority of the cases, this corrects the problem. However, if you JUST purchased this washer, and it is brand new (not used), I would recommend you use your manufacturer warranty (good for the 1st year in most cases) to avoid the risk of voiding it. The conditions of some warranties, prohibit the consumer from opening the appliance and attempting any repairs. Read the find print just to be sure.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 09, 2009
kel1guy2002
  • 3740 Answers
SOURCE: getting f21 error on my front loading 3000 series
F21 is too long to drain:: (more than 4 mins) Check your drain hose outflow into a couple of 5 gal buckets it should flow pretty fast. If not, there is both a suds sensor and the water level pressure switch that can be causing the problem. Since you do not have SUDS showing on your control panel I am assuming the suds sensor is fine. The water pressure switch itself can cause the problem even if you hear audible clicks when testing with an external hose. A clogged drain pump strainer can do the same thing. Lastly... the obvious... is the drain hose kinked???? Good luck and hope this helps.
Posted on Jan 11, 2010
SOURCE: We have a front loading 3000 series Maytag washer.
Just had this problem on Sunday. For a FRONT loading 3000 series, remove the front bottom panel (three screws - lay on floor and you can see them). There is a plastic can to the left of the pump. The front cover to this can screws on and off. Be prepared for water to gush out and unscrew the cover to the can. There is a filter/trap in there. Clean this out and it should solve the problem. Not sure why the manual does not cover this.
Posted on Jan 15, 2010
  • 1382 Answers
SOURCE: HE2 Plus front load washer keeps showing F21 error
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris. This solution will fix your problem.
Posted on Apr 01, 2010
SOURCE: Program computer-Maytag commercial washer mat12pdbaw
Try going to this website and scrolling down to find your Maytag Model number. Click on the model number and the programming steps should come up for you.
Anonymous
Posted on Feb 23, 2011
How do I reset/clear error codes F20 and F21 on my Maytag commercial washers?
Try to turn off power for 2 minutes and fool the washer into thinking it is new vs suffering a water loss. If that doesn't work see if there is a reset button on the mother board.
May 16, 2016 | Maytag Washing Machines
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Manual for MAH22PRBWW0
Here are the links to the Maytag website for this model number. There you will find four different manuals.
Warranty (1) Installation Instructions (1) Dimension Guides (1) Parts List (1)
Jun 22, 2012 | Maytag Mah22prawwo Front Load Washer
F21 code still flashes after i've unclogged line - reset?
if you cleaned out the pump by removing the center part of it and it still shows f21,either you didn't clear everything out of the pump,after you pull out the center piece stick your finger inside where the impellar is to see if you feel anything rapped around it,if it's clear and still won't drain then you need to buy a new pump and remove the old pump and install the new pump part number 280187 and it's around 120 dollars http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MFW9700SB1/3048/0153200/W0705107/00006?blt=06&prst=&shdMod=
Dec 10, 2011 | Maytag EPIC MFW9700S Front Load Washer
Customer has an f20 error code stuck Model MAH22PRBWW0
how can i fix f27 ive done every thing drain every thing check the hoes check the filter check the prussure switch check the drain pump the only thing a i can find is the therse is no power going in the inlet valve
Nov 14, 2011 | Maytag Neptune MAH5500B Front Load Washer
What does an F21 error message mean in a Maytag 5000 series front load washer>
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 15, 2011 | Maytag Washing Machines
F21 error on model mhwe300vw13 maytag 3000 it
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Aug 05, 2011 | Maytag Washing Machines
We got an f21 error code. What causes it and how can we fix it?
The F21 code on the Maytag EPIC is indicative of a pump problem. The pump impellers should be checked. There should be four of them. Sometimes the impeller blades can be broken by coins, etc. Make sure that the pump is clear of debris. Finally, remove the discharge hose, pucker up, and blow through it. If after clearing the initial slug of water, the hose doesn't blow free and clear, you have something stuck in there. Hope this helps you and best wishes.
Jul 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
