Question about Casio G-zone Commando
Contacts won't open
When pushing the contact button I get the message Unfortunately contact have stopped
My remote only turns tv on and off nothing else. TV model D40-D1
you can test your remote by looking at the LED emitter end of it while you are pushing the buttons that are not working. Look at it through the camera of your smartphone. Unfortunately this will not work with an iPhone because of the IR filter in the lens. If you do not see a light when you push the buttons, some of these contacts can be cleaned by opening the remote and cleaning the buttons and contacts with a clean pencil eraser.
Jan 03, 2018 | Televison & Video
Unfortunately Google Play services has stopped message appears on my mobile phone . How do I get rid of it as it comes up after every few seconds
Update Google Play Services to the latest version. You can download from here. You may be getting an error because you have a very outdated version or the one you have is having a conflict/bug with the current Android version in your phone.
Clear the Google Play Services cache. The Google Play Services app in your phone acts like a framework for all the Google and Google Play apps installed in your phone. You can try cleaning up its cache and see if that would fix the issue. This worked with one of our team members! Read these quick and easy steps : Go to Settings > Apps.
Scroll to All apps and then scroll down to "Google Play Services" app.
Open the app details and tap on the "Force stop" button.
Then, tap on the "Clear cache" button.
Clear the Google Services Framework cache. The Google Services Framework system app on your Android device stores information and helps your phone sync with Google servers - and keeps your Google Play Services up and running. This could be one of the reasons why you are not able to connect to Google servers using the app and keep getting the error message. Read these quick and easy steps : Go to Settings > Apps.
Scroll to All apps and then scroll down to "Google Services Framework" app.
Then, tap on the "Clear cache" button. Google Play Services Has stopped message continually popping up on my...
Nov 15, 2016 | Google Cell Phones
Perform cleaning on EcoQuest Fresh Air won't go away after pushing reset button
If you did not thoroughly clean the contacts for the ozone plate, the "Perform Cleaning" light will not reset.
May 05, 2012 | Ecoquest Fresh Air Air Purifier
1200 suzuki bandit, won't button start, will push & jump start, checked fuses
Try pulling the switch open, and clean the contacts, or make sure everything still connects as it should.
Check your connections at the starter and solenoid.
Mar 14, 2012 | Motorcycles
Beeps when buttons pushed, but won't start
Dear Sir:
Try it with some little Inyection of 50% of Oxigened Water +50% ethilic Alcohol(100%) for to clean the contacts or pad for the buttons.
Wait for 15 minutes.
An try it again.
Now if doesnot work go to the 2 Step.
2) You must open the cover, and look for the rely for to clean it contacts, in the same ways.The rely is the element for to swith off -and on the motor for Theadmill.
Respond it if you get solution.
sincerely.
E.Cuadra
Sep 05, 2011 | ProForm 980 CS Treadmill
No power to headlight!
Some bikes by design shut off the headlight while cranking the starter to conserve power. I'm not positive on your model, but Goldwings have this feature.
They do this by having 2 sets of contacts behind the starter button...so as you push in, first the headlight contacts open...then as you push further the starter circuit contacts close. Sometimes as these bikes age...the button doesn't fully release, so the starter contacts open, but the headlight contacts don't close.
With key off....spray a little WD-40 around the button and work in and and out several times, letting it snap out, then retry.
Apr 03, 2011 | 1984 Honda VF 1100 Sabre
How do you sent an SMS message to multiple recipients on the iPhone
Go to the Test Messages screen (touch the SMS button) and then touch the Compose Message button at the top right hand side of the screen (Do not start by using contacts or favorites or another way).
I opens a blank text message with the "To: " at the top.
Start to type the name of the contact (below you will see the contacts that match. At any time you can select any of those by touching them).
To add the next contact touch the "+" to the right of the first contact. It will open your contacts and you can select another or you can just type in the number of the person you want to add to the text message.
You can keep repeating this until you have them all in there.
When you have all the desired contacts in there, push "Send"
Dec 31, 2008 | Apple iPhone Smartphone
Casio G-zone Commando Logo
22 people viewed this question
Top Casio Cell Phones Experts
Oloyede Monsuru
ray gallant
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
