Question about Icom Programming Cable Lead Opc1122 Usb Ic400pro
Icon ic400pro I can get the scanner to work for 40 channels but won't scan 80 channel
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
Put all Channel which you want scan in the scan list.
Posted on Jul 11, 2016
What does it mean when a channel is "locked out"?
That is a setting that is used for channels that are constantly broadcasting but you don't want to scan them because they will stop the scanner. An example is the noaa weather channel. You may want to have it on the scanner as a channel but you don't want to scan it because the scanner will stop on it all the time.
Feb 25, 2015 | Uniden Bearcat 560xlt 560 Xlt 16ch Police...
How do you unlock channels on scanner
Hi Lori,
Many times, you need to switch to MANUAL mode (out of scan) and step thru each channel. The display will indicate if the particular channel is locked out by symbol or text. Pressing ENTER or LOCKOUT (depending on model scanner) should toggle a locked out channel back into the scan - and a scanned channel into lockout.
Without knowing your scanner model - it's difficult to tell you exactly how to do it. If my suggestions do not work, reply and include the brand and model number so I can get you the exact steps to solve your problem.
May 29, 2013 | Uniden Radio Communications
Channelslockedout
Hi Barney,
I take it that you have frequencies programmed into the scanner, so this is the solution to your problem.
On the keyboard of your radio scanner you will find a button marked L/O or L/Out, when your scanner is in scanning mode, press the Mon or Hold button, this will stop it from scanning.
Now select the channel of your programmed frequencies, starting with Channel 1. To do this press Hold followed by 1, if this channel shows a L/O icon on the LCD screen, press the L/O button and the L/O icon should go out. continue through each channel, until you undo the L/O from each channel by following the steps I have described above, once you have removed the L/O icon from all the channels that were locked out you can then press the Scan button and you'll be listening to the frequencies that you programmed into your scanner.
Note: If you have not programmed any frequencies into your radio scanner, then you will not be able to hear anything, as nothing programmed to hear and L/O is the default setting on all channels, until each one is programmed with the frequencies of your choice.
How to Program a frequency?
Press Prog button, select channel to store frequency, E.G:Ch:1 168.5000
Remember to always press the (.) decimal button in the correct place, else you will get ERR message on the LCD, now press Enter button, you now have the first frequency stored in you radio scanner on Channel 1, now press the Delay button, so that it doesn't start scanning for 2-3 seconds after a transmission is received.
Continue with the above setup one channel at a time until you have programmed your radio scanner to your liking.
I hope I have helped you in finding the solution to your query.
Regards,
Peter
Feb 22, 2013 | Radio Shack Pro-2096 Base Scanner
How do i start scanning for channels on my bc 855 xlt scanner
Firstly, you need to program your favourite frequencies into it, before you can receive anything, all the info on setting up your scanner is in the user manual that came with your scanner, if you bought it new, that is.
Cheers,
Peter
Jul 26, 2011 | Uniden Bearcat Pro PC78LTW 40-Channels...
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Mar 29, 2011 | Uniden BC370CRS Base Scanner
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
I reset my pro 82 scanner now i need to program my scanning codes
Your reset wiped out all programmed frequencies, leaving "000.0000" in each channel. That automatically sets the LOCKOUT icon, but it will clear when you program a frequency into the channel. You can download and print your scanner manual here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Need the frequencies for your area? Visit:
BillB
Jan 22, 2010 | Radio Shack Pro-97 Handheld Scanner
How to program my uniden bearcat scanner bc350c
to listen to the programed channels you need to turn the squelch up to to the right and press scan it will scan all the channels and stop on the ones that people are talking on. you can down load the user manual at the bearcat scanner website.
Jan 19, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Uniden BC72XLT compact scanner
Hi, this is from the manual,
Locking Out Channels
You can increase the scanning speed by locking out channels that have a continuous transmission, such as a weather channel. To lock out a channel,
manually select the channel, then press Func +L/O.
L/O appears.
Note: You can still manually select locked-out channels.
To remove the lockout from a channel, manually
select the channel, then press Func + L/O.
L/O disappears.
I hope this helps you out,,, Mechanic
If you need a manual, go here.
http://www.uniden.com/pdf/BC72XLTom.pdf
Jan 22, 2008 | Uniden BC72XLT Handheld Scanner
Icom Programming Cable Lead Opc1122 Usb Ic400pro Logo
87 people viewed this question
Top Icom Radio Communications Experts
peter0911
spencer hughey
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
