Question about Gateway CX2724 Notebook
Asus x55c boot in bios mode - Gateway CX2724 Notebook
How do I exit out of the uefi bio utility mode it keeps going back to the same screen when I exit
When it boots back to the uefi bios page there should be some settings tab/s that you can change the boot from uefi only to normal the only other things i can suggest if you dont want to go into those settings to far for whatever reason , when it boots into your bios from uefi mode press f10 or whatever the defualt settings button may be for your bios, make sure you save and exit then aoll should be fine , FAIL THE ABOVE , ITS TIME FOR A BIOS UPDATE !!
Dec 04, 2014 | ASUS Computers & Internet
Beep Codes?
This board has been known to have some issues, the Asus' PEG optimizations aren't fully supported by some video cards like the Gigabyte GeForce 6600 GT. One example of a fully supporting video card is the Asus Extreme Radeon EAX1900XTX.
If possible, try using a different video card (one that supports
Asus' PEG optimizations - PEG Link Mode overclocking feature; PEG Link for single/dual graphics cards ). Or you may want to try and disable the PEG entirely.
Hope this be of some help/idea. Pls post back how things turn up or should you need further information.
Good luck and kind regards.
Oct 21, 2007 | ASUS P5ND2-SLI (890552603831) Motherboard
Help forgot bios password for asus X55C-DH31
Why do you want to access the BIOS? You could reset the password by removing a small battery from the laptop ( if you don't know what you're doing I urge you to take it to someone who does know) if that doesnt work, sorry you're a bit stuck
Sep 09, 2014 | Computers & Internet
How can i bypass bios password
Solution 1: Unable to power on the notebook.
1.1: Reset hole available on the bottom?
1.1.1: Reset hole available. --> Use a spiculate pin to tip the reset hole.
1.1.1.1: Problem solved. --> Able to power on.
1.1.1.2: Problem persists. -->1.2
1.1.2: Reset hole unavailable. --> 1.2
1.2: Try to power on just using battery.
1.2.1: Able to power on. --> 1.3
1.2.2: Unable to power on. --> Check the adapter indicator.
1.2.2.1: Adapter indicator on. --> Try to power on just using adapter.
1.2.2.1.1: Able to power on. --> 1.3
1.2.2.1.2: Unable to power on. --> Contact ASUS service center for help.
1.2.2.2: Adapter indicator off. --> Adapter problem, check the cable or contact ASUS service center for help.
1.3: Try to enter the BIOS by pressing F2 button when ASUS logo appears.
1.3.1: Able to enter the BIOS. --> 1.4
1.3.2: Unable to enter the BIOS. --> Contact ASUS service center for help.
1.4: Try to enter the Operation System.
1.4.1: Able to enter the OS. --> Reinstall the OS for a try.
1.4.1.1: Problem solved. --> Able to power on.
1.4.1.2: Problem persists. --> Contact ASUS service center for help.
1.4.2: Unable to enter the OS. --> Contact ASUS service center for help.
this one is copyed.
May 11, 2014 | ASUS Computers & Internet
Asus x55c bios stuck
Please clarify. What do you mean by stuck?
Mar 18, 2014 | ASUS X55C-XH31 15.6" Laptop
Boot on sata
I found the user manual here :
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
Your problem could be in the bios. Press the delete key repeatedly while booting up to enter the Bios Setup Utility and check these options :
IDE Configuration - as shown in the manual at chapter 4 page 14
Onboard PCI IDE Operate Mode - Enhanced Mode
Enhanced Mode Support On - S-ATA
Configure S-ATA as RAID - no
and also
Boot device priority - as shown in the manual at chapter 4 page 33
set your Sata drive as the 1st boot device
For additional info, refer to the manual in the link above.
Did this solve your problem?
Dec 27, 2012 | ASUS P4P800 SE/865PE/SATA/R/A/GBE/1394...
Hello, I have a ASUS u43f-bba6 laptop. I accidentally pressed f9 during boot and I was taken to the asus system recovery screen. I pressed cancel when prompted to continue. The CPU just hangs in this...
If you can access the bios battery try resetting the bios by removing it . leave off for about a minute then replace. This will not affect your files.
Apr 26, 2012 | ASUS Computers & Internet
Asus A8N SLI RAID showing both drives as "degraded"
This problem usually occurs if: 1) The computer never finished booting 2) A sticky button on you keyboard (F8 or Control Key for win98) 3) Less Memory for windows xp and ME. Try checking if all the memories as well fixed on the board and are being read. 4) Corrupt system files. 5) Incorrect bios configuration (Try changing the bios settings to optimum performance of fail safe to confirm that. All the best.
Aug 25, 2007 | ASUS A8N-SLI Motherboard
Gateway CX2724 Notebook Logo
26 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
