Question about Thermador HNW48YS Stainless Steel Kitchen Hood
Everything was fine- all of a sudden the lights no longer work but the fan does- is there a breaker somewhere
Help
Why do the lights throughout the house pulsate when the washing machine starts agitating?
What make and model washing machine? How far is the breaker box from the washer?
Mar 24, 2017 | Washing Machines
Neither the oven's display nor the oven operate why?
Sounds like you have a blown fuse. Sounds also like it is an over the range unit and you definitely would need help if you have to take it down to work on. Depending on the brand and model, the fuse should be behind the touch panel somewhere. If you put in the brand and model with your question, it did not come through, so I cannot be more specific as to how to get into where the fuse might be located.
Jul 23, 2015 | Microwave Ovens
Bush ae56tcs the oven has suddenly stopped working. The light and fan isnt going on either. Everything else on the cooker is working (ie the grill and hobs)
-Check the breaker on the electric panel. Possibly two legs breaker, one pop out but still one on. you still have power but can't cook.
Good luck
Mai Lor
Nov 08, 2014 | Ovens
Casablanca Trident ceiling fan issue - light suddenly stopped working - replaced bulb to no avail - fan works fine otherwise...ideas?
Is it powered from the same breaker as the fan, check the breaker, if so check the connections. Most likely if its a pull chain switch the switch is bad,,,,, it's common..
May 29, 2014 | Dryers
Ge jvm1850sm2ss suddenly does not heat food any longer
time for a new one... new ones are cheaper then the parts
Apr 08, 2014 | Microwave Ovens
Crosley elect. range Model # CRE3880GWWB
Have you checked the breaker? The parts for that model are no longer available.
Feb 14, 2013 | Kitchen Ranges
Dww061350b
if both fan and light have quit working then you have an electrical supply problem. start with checking for thrown breakers in the breaker panel. if none are tripped then you have a broken wire or a wire no longer making a good connection. try twisting the wire nuts tighter were it wires in above it
Jun 02, 2012 | Kuppersbusch Kitchen Ranges
Headlights wont work, just suddenly stopped!
recheck them fuses sometimes they dont look blown but they are if not there must be a loose connection somewhere i know you have checked but retry
Jul 28, 2010 | 2005 Suzuki SV 650 S
My unit was working fine until 3 days ago when the breaker tripped, I reset the breaker and worked fine for a day then tripped again when it tripped both the ac breaker andthe main in the trailer as well...
High amp draw can be caused by a few different things, so first check that incoming voltage to trailer is sufficient. (115 volts) Not unusual for some parks to install more hydro hook-ups on a feed line, and when all are up and running, your incoming voltage could be decreased. If your o.k. that way, then I'd start looking at the compressor circuit of your ac, in particular, the compressor start-up capacitor. The capacitor basically stores electricity and boosts it to higher voltage for compressor and fan start-ups to reduce current draw that will trip the breaker. Please have a knowledgeable electrician, or RV tech check this for you, as a capacitor can give a real good high voltage (possible fatal) shock, even when power is off to unit. I also suspect that the start relay has shorted (welded) itself due to high amp draw situation, and that is reason it comes on by itself.
Jun 21, 2010 | Dometic Rooftop RV Air Conditioner
Thermador HNW48YS Stainless Steel Kitchen Hood Logo
64 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
