Question about Canon PowerShot S410 / IXUS 430 Digital Camera
PowershotA2400is len cannot retract - Canon PowerShot S410 / IXUS 430 Digital Camera
    Top Expert:
  • Canon Master
  • 6,702 Answers
Are you sure the battery still has enough power (even after charging) to let the lens motor do its job?
Are you sure there is no mechanical problem, you can see on the outside? Did anyone stop the lens, while it was coming out? Did anyone drop the camera, while the lens was out?
There cam be a lot of reasons, why a lens won't retract. Could be some force was used, also could be something just went wrong inside the camera. Like a gear that broke inside, or the motor stopped working. A contact failed and perhaps lots of other things.
If you already took out the battery, and reinserted it, and nothing changed, The only thing you than can do is after getting the battery out, is recharge the battery and then put it in.
If you have a spare battery, or you know anyone who has the same battery, try that battery. If nothing indicates a mechanical failure, and nothing helps, just contact the Canon Service Centre closest to you. First ask what a possible repair will cost. hen decide if you would like it repaired or you want a new camera.
New camera's are much better and cheaper than cameras last year.
Posted on Feb 15, 2014
Lens error
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
Oct 19, 2007 | Nikon Coolpix 5200 Digital Camera
LENS ERROR RESTART CAMERA
The lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Feb 25, 2011 | Canon IXUS80ISS Digital Camera
E18 lens will not retract
hi your answer of your problem e18 lens will not retract.
i have send this information to solve your problem.
Turned the camera on with weak batteries. Lens extended and won't retract.
Feb 15, 2010 | Canon PowerShot S2 IS Digital Camera
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Sep 25, 2009 | Samsung SL201 Digital Camera
Lens will not retract, camera was not dropped,
Leave the batteries out for a while and then try turning camera on..hopefully its resets the camera and retracts lens.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Lens wil not retract after battery died
It takes power for the Lens to retract. Recharge or replace batteries to get the lens to retract.
Jun 19, 2009 | Nikon Coolpix 5000 Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Cameras
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
