Question about Hayward Pool & Spa
Where is the riva flo priming plug
I'm looking for the riva flo priming plug
How do i bleed my aqua-flo flo-master XP2 pump? It starts up in both speeds but moves NO water. I am thinking I have air in a line
your pump will not prime with air in the line. Check the impeller for junk in it. Clear it out by opening the pump lid, and then opening the air bleeder on your filter. That will flush the stuff from the impeller. Check pump lid gasket, and make sure all your baskets(skimmer, and pump) are empty. Prime pump. That should get it flowing. Also, clean or backwash your filter.
Dec 30, 2016 | Pool & Spa
PRIME A GOULD PUMP
whats your question how to prime the pump? if so at the bottom is a 3/4 inch plug screwed into it, or at top, once the pump is hooked up to the lines turn off the power, and unscrew the prime plug fill with water, then screw in tight DO NOT USE THREAD SEALANT THEN THROW THE POWER TO THE PUMP, of course house supply valve must be off 3/4 turn valve off until the line is primed then open the supply line to house slowly to supply the water to all the lines, NOTE WHEN YOU FIRST INSTALL A NEW PUMP, HAS TO BE PRIMED, HAVE TO HAVE SUPPLY LINES FROM WELL TO HOUSE CLOSED TO PRESSURE THE TANK AND TO FILL THE LINES.
Apr 27, 2014 | Jet Flo 04325143A Marine Heavy Duty Water...
How do i prime my pond filter and pump
Consult your owner manual to achieve proper priming.
Apr 16, 2014 | Max Flo Waterfall Pump 2900 Gph
How do you prime a c48a95a06
plug at the pump housing open it while power off and fill screw back in power up
Oct 16, 2013 | Jet Flo 04325143A Marine Heavy Duty Water...
How to prime a gould j5 well pump no plug on top
you have to have electric power to use a jet pump more info needed as to what is going on
Nov 04, 2012 | Jet Flo 04325143A Marine Heavy Duty Water...
How do i prime a gould jet pump
turn pump on,pour water in the 3/4 plug on the top of pump.feathering the valve so its not open all the way.
Apr 26, 2010 | Jet Flo 04325143A Marine Heavy Duty Water...
Refilled my hottub and now there is a ''FLO'' signal and the heater will not come on. Pumps and jets work fine.
simple fix its one of two things you did not prime the spa when filling it meaning that u just did not lay a hose in the spa then fill it you always need to prime the heater first along with the circ pump if you do not you will get a thing call airlock which is what it sounds like air in the main circulation pump for the heater.Also could be that u removed the filter while you still had the spa running an clogged the circ pump or it could be the flowswitch. Sounds like u might have a sundance spa an if the flo is flashing its either the air lock or your pump went or its clogged if the flo sign is not flashing then its the flowswitch but in that case w/a solid flo nothing would b working. To fix the airlock just shut the power down an take your hose an force water into the intake side of the filter area this is what u should always do 1st when you fill it that how you prime yuor pump an when fillin it all the way it best to fill it through the other end of the filter just put the hose into the filter tube w/the screw on it.IF THATS NOT IT THEN FEEL YOUR CIRC PUMP IT WILL BE THE SMALLEST PUMP IN THE SPA IF U CAN NOT TOUCH IT FOR MORE THEN A FEW SECS. THEN IT WENT ON U OR IT CLOGGED
Jan 29, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Does the power flo lx have to be installed below the water level
Yes it does; it is not self-priming and will not work if the pump or the pipe leading to the pump suction is above the water line.
Oct 16, 2009 | Hayward Power Flo Lx
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
Pool & Spa Logo
16 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
