Question about Baby Lock Ellure
Skip stitches My Allure skips stitches constantly. I am careful about having the correct needle. It has been in for servicing three times for this and it still happens.
  • 3 Answers
Take it back in to the repair shop, it until they fix it right. I have many machines and only one will do top stitching evenly without having to rip it out. very frustrating indeed. Good luck!
Posted on Jun 04, 2014
3 Suggested Answers
  • 1116 Answers
SOURCE: My needle on my Esante seems to be hitting
Did you thread the machine with the presser foot up? Is the needle inserted with the flat side to the back of the machine?
If so, and the problem has not changed, check the bobbin case to be sure it is correctly placed into the race. Leave the needle plate off as you hand walk the needle down. If it hits the case, it is not in place.
All the above has been done and problem continues, take the machine in for service as the timing may need adjusting and is a process best done my an authorized Brother dealer.
Posted on Mar 11, 2010
Tally Girl
  • 1125 Answers
SOURCE: left needle on baby lock serger "imagine" skips
Change needles if they have done a few hours. Ales use ballpoint if seaming stretch fabrics. Also you can get EL 705 needles, which have a longer scarf (groove at back) which helps with the loopers catching the needle thread. Or SUK is the stretch type with this longer scarf Also if you are using cheaper thread cones, try a better quality with smoother finish and consistent weight, this will help too. However if this doesn't resolve issue, your looper timing might need adjustment.
Posted on Nov 11, 2011
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Skip stiches
Changing the needle may be helpful. A bent/damaged needle will tend to not pick up the bobbin thread properly.
Try a different type of thread--avoid old or bargain bin threads.
Could also be an incompatibility of the needle, thread, and fabric.
All About Needles
If it still skips stitches, then it may have a needle/hook timing issue that would require service.
Aug 19, 2016 | Sewing Machines
How can i fix this please.
Be sure to install a brand new needle. Bent/damaged needles will often cause skipped stitches. Also, make sure to use the correct needle for the thread and fabric. AVOID old thread or thread from the bargain bin. They are cheap and there's a reason why they are...
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiG3KCum8nNAhVO8WMKHVvWD8oQjBAILDAC&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
All About Needles
Jun 27, 2016 | Sewing Machines
Why is my singer 9015 skipping stitches, particularly on zig zag setting???
There are several possibilities for skipped stitches. A needle that is dull or bent; using a ball point needle when a sharp should be used, such as a woven fabric, the needle is not all the way up in the needle clamp; the needle was not inserted with the flat side in the correct position (unless your bobbin case is on the side of the machine, that's toward the back), or the top thread and or bobbin thread is not threaded correctly.
Sep 13, 2014 | Sewing Machines
Skipping Stitches My Singer Confidence machine is skipping stitches. I've cleaned the feed dogs and the stitch hook, changed needles three times, changed thread, adjusted the tension, etc.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
Oct 07, 2013 | Sewing Machines
My New Home skips stitches. I have cleaned it, changed needles, adjusted the tension and tried different bobbins .
Skipped stitches
it's also possible that the machine could be slightly out of time
Aug 29, 2012 | Sewing Machines
Skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
May 07, 2009 | Juki DDL-8700
Sewing Machines Logo
61 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
