Question about Dishwashers
How do you install hinges for a vista avalon toilet seat
  • 2712 Answers
SOURCE: How to install Toilet Seat
Use a flat head screwdriver to pry open the plastic pieces that cover the screws. Using the same flat head screw driver, unscrew the large plastic screws holding the old seat in place. There are usually plastic nuts on the underside that you can hold on to while removing the screws. Remove the old seat. Clean the area where the screws were and dry thoroughly. If the new seat has an adhesive pad, remove the covering from the adhesive and put the seat in place. Thread the new screws through the holes and attach with the new nuts. If there aren't new nuts and screws, you can use the old ones, provided they weren't damaged during removal. Snap the caps covering the screws on the new seat in place. Be careful not to over tighten the screws! Since they're plastic, they can be easily damaged by a screwdriver!
Posted on Aug 27, 2008
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
tsolinac
  • 28 Answers
SOURCE: Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
Posted on Feb 27, 2010
  • 31 Answers
SOURCE: How do I adjust hinges on a soft close toilet seat
it does this get used to it.
Posted on Apr 11, 2010
  • 1739 Answers
SOURCE: The hinges of Duravit toilet
I have not been able to find a "tribeca" on the Duravit website but on the site of one of their parts distributors I found the Duravit Toilet Seat DUR 006331000. Is this your model? Starck 3
On the Duravit website this product looks very similar but not the same number.
I was not able to find replacement hinges for this model sold separately. You might consider using their Find a Retailer feature to find an outlet close to you where you might make inquiries or order hinges and/or a new lid.
Posted on Jan 27, 2011
Testimonial: "Thank you for taking the trouble to do the research and provide me an answer. Very helpful! "
How to remove a parisi nahm soft close toilet seat
there is 1 of two ways.
easy way is have a look where the seat mounts to the toilet and see if there is a cover that you can lift up and find a screw under it. there might be 2 pins on each side of the toilet seat hinge that you depress for you to remove the seat from the hinges to access the screws.
failing the above method the toilet has to be removed to access the screws / wingnuts from under neath. send closer picture of hinge on seat if you like.
Jul 12, 2014 | Toto Aquia II Dual Flush Toilet
Porcher Toilet Lid Hinges are loose
Tinkerbellpp is right about the 70032-00.001being out of stock. You can replace this with the 70030-00.001(chrome hinges) seat which will fit the Veneto Toilet. You can find this at your local dealer/showroom. Hope that helps!
Aug 29, 2012 | Porcher Toilet Seat Veneto 70032.001
Toilet seat install
at the hinge of the seat there are caps that should snap open. underneath there are two bolts simply unscrew then then replace the seat
Oct 09, 2011 | Kohler - Toilet - Two-piece - Highline -...
Hinge on quiet close stopped working
A lot of these slow closing toilet seats don't work well, so I suggest an alternative, Drop-a-Seat cushions. They stick on to the bottom of the toilet seat, allow you to drop any toilet seat, gravity does all the work, and the cushions absorb the impact. They're non-absorbent, stick on for easy installation (permanent yet removable), and are only $4.99. Check them out at www.drop-a-seat.com
Aug 14, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
What toilet seat hinge replaces Bemis elongated closed front toilet seat (plastic/not a bar/pair of hinges) and who sells? Can't believe Bemis does not support to proclaim hinges set in warm plastic...
The hinges and bumpers on plastic seats are not replaceable. The bumpers are molded in and the hinges are installed with special tools while the plastic is still warm.
Sorry but that's way Bemis does things and is way most good Plumbing shops will not buy or sell them.
They were not like that untill they started having their seats made in China however this may help you http://www.bing.com/shopping/search?q=bemis+toilet+seat+replacement+parts&FORM=HURE
http://www.bizrate.com/plumbing-supplies/oid1620858646.html
Mar 11, 2011 | Bemis 7MCLRDRCT NA Elongated Toilet Seat...
The hinge part of the toilet seat installed alright---but once the seat was connected to the tank, i tried to open the lid and it just fell off---the quiet close "dowels" for lack of a better...
Hi, Please don't take this the wrong way but did you install the hinges the right way? I fit bathroom suites for a living and have done this a few times wrong by putting the left hinge on the right side and vice verser. Sometimes the instructions are not very clear in explaining which side is left on the seat, as a result even though the toilet seat is closed, the springs are set backwards and are in fact in the up position. Double check the instructions once more, and just have a look on the hinges and seat because sometimes they have a small 'L' sticker on the hinge and an 'L' sticker on the seat and lid to correspond which hinge goes on which side. Hope this is of help to you.
Jan 11, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
Feb 13, 2010 | Neptune FB1621 Murano Toilet
Problem with seat hinges
The best fix here is to purchase two new seats which come with the hinges attached. they are easy for the home owner to install. You can get them at any home depot or lowes where u will have many choices of color, design etc. Be to sure to note whether your toilet seats are round or elongated as you will want a round sear for a round toilet and an elongated seat for an elongated toilet. get back if you have any questions. the new seats will cost 15-40 dollars each depending on which ones you select.
May 06, 2009 | Home
Dishwashers Logo
217 people viewed this question
Top Dishwashers Experts
