Question about Plumbing
Failure light remains, refusinig to start
This is a Riva Flo pump connected to a small water tank of 3300 litres. Attempts to turn on results in no pumping of water and the failure light is on
  • 19 Answers
SOURCE: Losing coolant thro the expansion
Not too familiar with this model but.... First some questions! Has the fault started after the pipes & rad replaced or were they replaced to remedy problem? If fault happened since work then i'd suggest an air lock in the system in which case you will need to 'bleed' the system of air. Make sure the expansion tank is the highest point & look for any bleed valves on the hoses - usually near the heater matrix. Sometimes it may be necessary to help the process by removing the temperature guage sender unit to allow the air to escape as air cannot pass through a closed thermostat. If the fault was there before, does the expansion tank seem to build up pressure very quickly? Do lots of air bubbles appear with the engine running & the pressure cap off?
Posted on Aug 22, 2008
  • 10 Answers
SOURCE: pump works but is not pumping water
IT SOUNDS AS IF THE PUMP IS NOT PRIMED. MAKE SURE THE THE PUMP IS FUL OF WATER
Posted on Jan 11, 2009
motor1258
  • 6674 Answers
SOURCE: water pump 1998 sunfire gt 2.4 litre
Here's alink, scroll down side to 2.4L, click on pictures to expand/enlarge .
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528003cbf6
Posted on Jan 25, 2009
SOURCE: Secondary air supply failure
I have a 2005 Envoy with a 4.2..... Just recently the check engine light illuminated so I read the code after replacing the 20amp fuse labeled cigar. My OBDII connection had no power so if you plug your reader in and nothing check the fuse under the hood labeled "cigar"
After pulling the code P0410 Secondary Air Injection Malfunction I checked the operation of the air pump by removing the hose connected to the solenoid. By the way the solenoid is located on the pass side of the engine top towards the back. After pulling the hose off the solenoid I started the vehicle when it was cold and after 20 seconds or so the pump should turn on and blow air out of the hose. Once I verified the pump was operating I pulled the solenoid then placing jumpers from the Positive & Negative of the battery to the pins on the solenoid. You should be able to hear the solenoid click which says its operating. But mine did nothing so I read across the pins with an Ohm meter and verified the coil was good.
So take some good penetrating oil and fill the inside of the valve with it. You can see the plunger shaft assy in the opening and thats the area you want to fill with a good penetrating oil!!!! Let it sit for a couple of hours keeping it full of oil. The housing is aluminum and the shaft is likely to be a brass material so rust is not possible. Its caused by a buildup of carbon!! The penetrating oil will soften the carbon which in turn will free up the plunger!! MINE WORKS GREAT NOW and plus you will save around $140.00 if you were to buy it from the dealer!!! Or $80.00 aftermarket from RockAuto.com
Posted on Feb 10, 2009
  • 104 Answers
SOURCE: Flotec Shallow Well Jet Pump won't pump water
The tank is an air tank, it works like a cushon and accumulator.
Have you reconnceted the pump? If not fill the pipe that goes to the well with water. It should not drain down, there should be a foot valve that prevents the water from running back into the well. So if the foot valve is working it should not take a lot of water to do this.
Pour water into the suction side of the pump until the pump is as full as you can get it, reconnect the pump and start it up. Yes it does need to be primed
Good luck
Posted on Mar 17, 2009
Hi we have a aspen trail 2012 2810 bhs. I drained the fresh water tank before moving. Since when tank is full the pump runs out of water after 40 litres. Any ideas please Stew
Look inside the tank to see if a small piece of plastic has found it's way into the inlet line to the water pump. It happens more often that you think.
Mar 23, 2018 | RVs
If i have a diesel engine and my tank is 80 litre and put 70 litre diesel and 10 litre petrol in my tank what will happen to my diesel engine than
That depends on the amount added and the engine, yours would be 7 parts diesel to 1 part gas. I do not have the different effects on engines using different ratios of deisel to gas, I suspect the richer the mix ratio of gas to deisel, the more noticable the reactions will be. First off there are two immediate impacts of diesel fuel mixed with gasoline: the octane is lowered and the fuel vaporization is reduced. The lowered octane may cause the engine to knock. Some engines have knock sensors and the electronic controls that will adjust the timing and other engine conditions to try to control the knock. If the knock remains significant it can damage the engine by causing metal fatigue eventually leading to failure of critical parts like pistons, connecting rods, heads. Some very old engines (e.g. 1950's tractors) can accomodate lower octane, but the ones found in recent autos are normally running close to the knock threashold. The reduced volotitility caused by the added diesel will cause hard starting and will probably result in some unburnt hydrocarbons remaining in the exhaust gas from the engine; these may be reacted in the catalytic convertor causing it to overheat. A modern electronic controlled emission system controls the oxygen level in the exhaust gas going to the convertor so the significant increase in hydrocarbons with controlled oxygen may save the convertor, but will likely result in unburnt hydrocarbons exiting the exhaust. This will result in a smell and air pollution. Gas will also damage deisel fuel pumps as well.
Dec 15, 2013 | Cars & Trucks
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Descale
Delonghi EAM, ESAM, ECAM, Nespresso
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the appliance displays the message:
DESCALE
you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the button (the light over the button comes on) then press the button repeatedly until
the appliance displays:
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RISRINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Nov 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Apr 16, 2010 | Hayward SAND FILTER, PRO SERIES
How do you get the top of a fuel tank off of a 2001 ford expedition? We are trying to replace the fuel filter.
Ford Excursion, Expedition, Lincoln Navigator 2000-2005
2001 Ford Truck Expedition 4WD 5.4L EFI 8cyl
Fuel Tank - Removal & Installation
CAUTION Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related components. Highly flammable mixtures are always present and may be ignited. Failure to follow these instructions may result in personal injury.
CAUTION Fuel in the fuel system remains under high pressure even when the engine is not running. Before working on or disconnecting any of the fuel lines or fuel system components, the fuel system pressure must be relieved. Failure to follow these instructions may result in personal injury.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Disconnect the battery ground cable.
  3. Relieve the fuel pressure.
  4. Drain the fuel from the fuel tank.
  5. Raise and support the vehicle.
  6. Disconnect the fuel tank filler pipe hose and the filler pipe vent tube from the fuel tank.
  7. Position a jack under the fuel tank
  8. Remove the four fuel tank cover strap bolts
  9. Partially lower the fuel tank
  10. Disconnect the fuel lines from the fuel pump.
  11. Disconnect the fuel pump electrical connector
  12. On gasoline fuel tanks, disconnect the hose(s) from the evaporative emission valve.
  13. Lower the fuel tank
  14. If a new fuel tank is being installed, transfer the necessary components to the new fuel tank.
  15. To install, reverse the removal procedure and note the following:
  16. Tighten the fuel tank strap bolts to 98 ft. lbs. (133 Nm).
WARNING Fuel injection equipment is manufactured to very precise tolerances and fine clearances. It is therefore essential that absolute cleanliness is observed when working with these components. Always install blanking plugs to any open orifices or tubes.
  2. With the vehicle in NEUTRAL, position it on a hoist.
  3. Release the fuel system pressure.
  4. Drain the fuel tank.
  5. If equipped, remove the four nuts and the fuel tank skid plate.
  6. Disconnect the two vapor tubes at the rear of the fuel tank
  7. Disconnect the vapor tube and the fuel filter outlet tube forward of the fuel tank.
    NOTE Do not support the fuel tank directly beneath the fuel pump mounting area. Damage to the fuel pump assembly can occur.
  8. Position a suitable jack under the fuel tank.
    NOTE The location of the fuel vent hose is critical to fuel system operation. Note the routing of the fuel vent hose at this time.
  9. Remove the two bolts and the fuel tank front and rear support straps. Lower the front of the fuel tank approximately 1 inch. (25 mm).
  10. Disconnect the vent tube from the fuel pump module.
  11. Disconnect the fuel pump module and fuel pressure transducer electrical connectors.
  12. Remove the fuel tank from the vehicle.
  13. To install, reverse the removal procedure and note the following:
  14. For 2005 models if removed, tighten the fuel tank skid plate bolts to 15 ft. lbs. (20 Nm). For 2006 models 22 ft. lbs. (30 Nm).
  15. For 2005 models tighten fuel tank strap bolts to 35 ft. lbs. (47 Nm). For 2006 models tighten strap bolts to 30 ft. lbs. (40 Nm).
Fuel Pump - Removal & Installation
CAUTION Fuel injection systems remain under pressure, even after the engine has been turned OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
  2. Remove or disconnect the following:
    Negative battery cable Fuel pressure Fuel tank skid plate bolts and lower the skid plate Fuel Fuel tank filler pipe hose from the tank Fuel tank filler pipe vent hose from the tank Fuel lines from the fuel pump Front fuel tank connections Rear Evaporative Emissions (EVAP) hose clamp and the hose Electrical connector from the fuel pump
  3. Support the fuel tank with a jack.
    Fuel tank support strap bolts and the fuel tank straps Fuel tank Fuel pump lock ring Fuel pump
More details in autozone.com (free register).
Hope helped (remember rated thie help).
Oct 19, 2009 | 2001 Ford Expedition
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
Plumbing Logo
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
