Question about MSI Computers & Internet
No screen display on MSI A6000 laptop
Working fine earlier today. Is there a button to push to jar the screen display to come back on?
martmet
  • 52 Answers
SOURCE: Screen not working on ACER 5315 laptop
First be sure you dont have an imput problem on your laptop while you are testing it. The input buton (swtich view) should be acessible via the Fn button and the F3-F8 on the keyboard (depends on your model) but it could looks like this : |[]| it really depends on the brands/models. It seems you experience some driver issues, but the driver should work for both devices... It's possible that your laptop screen or inverter are defective. But before saying so, be sure to try to switch views while you got the external monitor plugged in and see what happens. If only your external monitor works fine, you may have to replace some hardware in your laptop. I would personally contact the Acer technical support before spending any money on it though. Just in case... I hope it still in warranty cause it may be a bit expensive otherwise :(
Posted on Jun 08, 2009
ajx13
  • 110 Answers
SOURCE: my laptop has no display
If the lights on the laptop are coming on and the screen is blank it can be a video card or LCD failure. Also other hardware conflicts can cause this. Try running the hardware tests.
First you'll have to power off the system.
You need to hold down the Fn button (Located next to the CTRL button on the left hand corner) and then power on the system. This will take the system to the diagnostics mode.
The tests will let you know more about the problem.
Incase you do not see anything on the screen in the tests look for the 3 lock lights above the keyboard. Note their status of the 3 lights.
Posted on Aug 11, 2009
SOURCE: no display at power up.
I think your motherboard and the processor did not match well so this problem might be occur..
Posted on Sep 09, 2009
  • 21 Answers
SOURCE: compaq laptop will not power up
try taking the battery out, make sure the ac adaptor is not connected, hold down the power button for 60 secs and then put the battery back in and try turning it on.
Posted on Sep 14, 2009
benwabnick
  • 2404 Answers
SOURCE: card reader on MSI A6000 doesn't reconize card
Try different cards in the slot, if none of the cards are being recognized then go into the device manager and make sure the card slot drivers are intstalled, if you see something that says pci base device then that means the drivers are not installed.
In that case you need to install the drivers for it. If after you install the drivers the slot still doesn't work then that means the slot is bad and since its built onto the motherboard the motherboard needs to be replaced.
Posted on Dec 17, 2009
Testimonial: "Thanks it was a card problem. I tried a different SD card and it worked fine. Didn't think that was it because I had used a usb device & it worked "
Msi A6000 USB HDMI and Audio jacks don't work
What is the OS?
Normally if the USB does not work, you can delete all the USB devices in Control panel and reboot.
Windows will reinstall USB drivers automatically,
After that please download latest driver for VIDEO card, Audio and from MSI.
A6000 is also called CR600?
Aug 22, 2014 | Computers & Internet
Screen
You may have a faulty inverter.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 17, 2013 | MSI Wind U110-031US (9S7N01212031) PC...
All i need is a ribbon cable for a msi a6000 computer screen
Good old E-bay listed under digital camera parts for your make and model.
Jan 27, 2013 | MSI Computers & Internet
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
Computer turns on to the windows screen and then a blue screen flashes too fast to read what it is saying. It then opens to a black screen with several options :open in safe mode, last known recovery, etc....
Usually blue screens are caused bu problems with hardware. Since the laptop was dropped, I would suggest opening the access doors and taking out each removable component and then reseating them back in their positions. It sounds like perhaps something has been jarred out of place such as a memory module, hard drive, etc. Start with those two and try to boot the laptop after each try.
Aug 01, 2010 | MSI Wind U100-030US Laptop
MSI A6000-029US Webcam does not appear
Have you enabled the function key for it? on the wind u100 it if fn key and f6
Mar 15, 2010 | MSI Wind UmNotebook
Add ram to MSI A6000.
Down load the MSI A6000's from its web site,then get msi on the phone and/or write them asking for the repair manual.
Feb 15, 2010 | Computers & Internet
Keyboard is not working in msi A6000 laptop
if the problem is that keys are typing it could be that the cable came loose. Open laptop and disconnect cable and reconnect and restart the computer it should work.
Jan 26, 2010 | MSI Computers & Internet
Webcam not recognized or working on MSI A 6000
1. Use "System Restore" to rollback to the previous settings.
2. If it don't works, check ur driver CD/DVD which came with ur sytem.
Jan 03, 2010 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
