Lost power cord to yamasa ,magic pulsar slot machine,will any power cord work
Magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Dec 27, 2013 | magicJack Plus Pc To Phone Adapter
Emachine T3042 BEEP CODES
Remove the power cord, open the case and sit the computer on its side. If you have more than 1 memory chip inside the computer remove 1 and set it aside. Now plug the power cord back in without putting the case back on and press the power button. If it boots without beeping, the mark an x on the memory chip that is set aside because it is probably bad. If it does not boot, Remove power cord, move the memory chip that is inside the computer to the next Memory Slot and then plug in power cord and reboot. If it boots, remove power cord, put the memory chip that is set aside that has the x on it into the open slot and then reboot. If it does not boot we definitely know the chip with the x on it is bad.
To verify further that the chip with the x on it is bad you can remove the chip without the x marked on it into both memory slots like we did above while the other chip that seems to work is set aside.
Mar 25, 2012 | E-Machines eMachines Desktop PC
The HP laserject 4000tn printer has come up with error code: 82.0180 - E10 2 error - what does this mean?
The EIO accessory in slot 2 has encountered a critical error as specified. On the back of the machine you have a additional card installed (Network Card, Hard drive, USB, etc.. ).
Steps to resolve:
Turn machine off and unplug power cord.
Re-seat the card in the EIO slot. Power machine back on, see if it works.
If machine still displays the error - Install the card into the other EIO Slot,(Their is 2 slots on the back of the formatter) Power Machine back on to see if it works.
If Problems still persists:
Remove the card from the machine, Turn machine back on and see if it comes up to a normal operation. If the machine is working correctly, it's most likely a Bad EIO Card.
If machine still doesn't operate as it should you will probably need a formatter.
Hope this helps.
Mar 01, 2011 | Office Equipment & Supplies
I have a pulsar watch, gold plated model number Y112-5299 570261. I need to find out what battery I need for this watch, the one that was in has been lost.
The movement for this watch is obsolete so I cannot find a spec sheet for it. From memory I think it is a 371 (SR920). If you can give me the exact measurements of the area the battery slots into (DEPTH and DIAMETER) (in milimeters) then I can tell you exactly which battery.
Sep 22, 2010 | Pulsar Watches
Lost AC plug-in power cord. Is it possible to
What fax machine?. if it looks like a computer power cord plug, that's what you need.
Feb 23, 2010 | Office Equipment & Supplies
Loss of power. Cord good still no power
the relay has failed in your speed control
repair or, replace the control
Sep 19, 2009 | Janome Memory Craft 3000
Fax machine shows message "external phone". Machine is a Philips Magic 3 primo
The message means that a telephone connected to the machine is off hook. Either that or the internal relay that seizes the line after a phone is used has hung up. In that case, try removing the power to the machine and unplugging the line and any other phone cords connected to the machine. Then 1st plugging in the power cord and wait until the machine powers up. If the error code doesn't appear, then plug in the line cord.
Aug 19, 2008 | Office Equipment & Supplies
Power supply cord
You can use any ordinary cord that will fit the slot of your xbox. Just make sure is for the 120 VAC.
No harm to the Xbox.
Feb 15, 2008 | Microsoft Xbox Console
TV signal lost
Have you had a look at the cords? Is there any damage to the hardware itself? Maybe there is something else wrong. Tried running virus scans? I know it's a long shot but it's amazing at what viruses do to your machine.
Mar 24, 2007 | ASUS V9520 Magic/T NVIDIA GeForce FX5200,...
14 people viewed this question
jasbo
jasbo
