Question about Gateway Desktop / Intel Pentium Processor / 6GB Memory / 1TB Hard Drive (SX280325E)
How to remove hard drive from gateway sx2803-25e
How do I remove the hard drive from my 2000 Gateway computer?
Why?
If you have to ask this question, you probably shouldn't do it.
Aug 01, 2014 | Gateway 2000 Computers & Internet
Where is the hard drive on a gateway all in one computer. i opened it up and dont recognize which part it is.
Hello.
Which model Gateway all in one do you have?
I have a Gateway ZX4800 and the hard drive is under the center rear cover. You have to remove the smaller panel that sticks out near the base of the PC (where the RAM is located) first then the center panel that is taller will pull out and reveals the hard drive cage. unbolt the hard drive cage, remove the SATA and power cables and you can then replace the hard drive.
On other All In One PC's (like the HP TouchSmart series) there is a rear cover that is under the desktop stand that can be removed and the hard drive is in a metal rectangle cage on the left side.
So, in almost all AIO systems, the hard drive is accessible by removing one or two panels off the back of the unit. RAM for these units will also be visible too.
Nov 02, 2013 | Computers & Internet
Gateway NE56R
1. Flip your unit over to its back and remove the battery.
2. Remove the screws on the large cover and remove the cover.
3. You will find the memory and hard drive under that cover.
P.S you should use a static guard to remove any of those parts.
Hope this helps
Feb 18, 2013 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
Gateway w650i Physically removing a hard drive my laptop help
I ran into this same problem on the exact model laptop. The solution is to remove the two screws that are in the laptop hard drive on the right... Those are obvious... The next step is to remove the two little white space fillers that are to the left of the laptop hard drive on the furthest side from where you removed the screws. That allowed the entire hard drive to now slide to the left toward where those place/space holders were. (don't lose those white pieces) Once you have the hard drive slide all the way left away from the connectors that were holding it in place you can slide up one side of the Hard Drive and easily pull it out!
Apr 08, 2010 | Gateway Computers & Internet
How do you replace a Gateway LT1005u hard drive?
with the laptop upside down there will be a hard drive cover. On most Gateway machines, labels and stickers are often placed on the hard drive panel.
Remove the two screws. MAKE SURE you keep these screws in a safe place
Slide the enclosure out of the laptop.BE CAREFUL and slow as to NOT damage the drive.
Turn the enclosure over. The drive will be screwed to the enclosure. NOTE as This is actually an anti-static container, so again be careful when removing, to avoid static
Remove the screws to actually remove the drive. keep these screws as may be needed for the replacement hard drive
Mar 19, 2010 | Gateway Computers & Internet
What is the easiest way to remove hard drive from a Gateway T 6313??
I have a Gateway 7510GX. Turn the laptop over. On the side closest to you should be a cover that is held in place w/one or two screws. Reomve this cover and the hard drive should be underneath it. One screw is all that is holding the hard drive tray and the hard drive in place. Remove the screw and gently wiggle the tray loose. There are probably four screws holding the hard drive into the tray. Replacement is the opposite of removal.
Dec 25, 2009 | Gateway T-6313 PC Notebook
Want to remove my hard drive before I recycle my computer
Open the two sides . Remove the wiring frm the hard driver. Remove the hard drive from the cage.
Apr 04, 2009 | Gateway GT5220 PC Desktop
Gateway MT 3705 Hard Drive
Open the case, unscrew the hard drive, unplug it from the mother board.. and remove it..
Oct 28, 2008 | Gateway MT3705 Notebook
I have 2 Gateway laptop computers and in one of them the CDROM Drive got fried. I would like to replace it with the one from the other laptop. How do I exchange them?
Before beginning, review electrostatic discharge (ESD) precautions. Disconnect the power adapter, the modem and network cables, and remove the battery before removing the hard drive bay cover. Remove the RAM door whichi s secured by one screw. Now loosen the two hard drive screws and pull the DVD/CD-RW drive from the laptop. Replace the cover before restoring power or reconnecting the modem and network cables.
For Gateway go to http://support.gateway.com/s/Mobile/Gateway/M275/3501734faq42.shtml
Aug 24, 2008 | Computers & Internet
Gateway Desktop / Intel Pentium Processor / 6GB Memory / 1TB Hard Drive (SX280325E) Logo
135 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
