Question about TOMOTOP YONGNUO YN568EX II Master TTL Flash Speedlite High Speed Sync for
Yongnuo YN568EX II on Canon 30D. Zoom is stuck flashing 14mm. Won't cycle when pressing the zoom button
Can't get is to stop flashing 14 in the zoom area. Zoom button does not change anything
ZOOM BUTTON STICKING..how do i fix this?
It is possibly an issue with the zoom motor, not the switch itself
Aug 21, 2017 | Agfa Cameras
Shooting with a Nikon zoom such as 18-200 with a Nikon SB800 flash on a Nikon D300 body. I make an exposure of a person and the result is exceptable and then I zoom to the whole group of five people and it...
Depends on the zoom length. If you check exposure at zoom 18 mm then zoom to (lets say) 100 for the final picture the flash will zoom concentrating the flash power as well; the flash gets stronger. This is all explained in the SB-800 manual. On a zoom such as the 18-200 the more you zoom the smaller the f/stop. You are better off with a zoom that maintains its f/stop through the entire zoom range. That way when you check exposure at 18 mm lets say f/2.8 then zoom in it will maintain the same f/stop. Myself I am not a big fan of zooms especially ones when zoomed change to a smaller f/stop.
Aug 05, 2010 | Nikon Speedlight SB-800 TTL Flash
Canon Speedlite 430EX zoom issue
You're gonna kick yourself, but here goes, you know that clear plastic wide beam shield on the front, make sure it's fully inserted or else the auto zoom won't work while it's in use, (or the flash thinks it's in use)
Aug 07, 2008 | Canon Speedlite 430EX TTL Flash
Camera really messed up!
Have you tried taking out the batteries and leaving it alone for a bit, then loading new batteries? I would try this first before anything. Good Luck.
Apr 09, 2008 | Casio Exilim EXZ75 Digital Camera
Sticky zoom button
I put some isopropyl alcohol on a cotton swab and gently cleaned the area around the zoom button, and now it moves freely.
Feb 17, 2008 | Canon PowerShot SD600 Digital Camera
How do I change the date? I don't have a manual.
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 13, 2008 | Canon Sure Shot Z180u 35mm Point and Shoot...
Need to set the date and can't find manual--
Try this:
Dec 22, 2007 | Canon Sure Shot 115u II Date 35mm Film...
Stuck in manual mode
Check that the wide angle pull out filter is pushed in proberly until it clicks in place also in custom menu check that M ZOOM is set to OFF. (hold zoom and - buttons together for a couple of seconds to enter and exit custom menu)
Oct 06, 2007 | Nikon Speedlight SB-600 TTL Flash
TOMOTOP YONGNUO YN568EX II Master TTL Flash Speedlite High Speed Sync for Logo
108 people viewed this question
Top TOMOTOP Cameras Experts
Are you a TOMOTOP Camera Expert? Answer questions, earn points and help others
