Question about ESP Music
Bridge pickup works with toggle switch up but in middle does not and in down position lower pickup doesnt work
    Sergeant:
  • 195 Answers
Try checking out the wiring on your switch...if all is good try replacing the switch altogether...one of the other is bad...Good luck
Posted on Feb 24, 2015
4 Suggested Answers
  • 10 Answers
SOURCE: Problem with volume dials in an electric guitar.
If you can't clean the pots or if you just want to try replacing them, try using
500k pots again, in case one or both of the pots is worn or dirty or
defective. If that doesn't work, and cleaning or replacing the
switches doesn't work, then the problem is probably elsewhere.
You could put a 500k resistor (with a sufficiently-high power rating of at least half the power rating (Watts) of the pot) in parallel with the pot, or, to cover all bases, put a 500k resistor from each of the two outer lugs of the pot to the middle lug. That should change it into the equivalent of a 250k pot. You could even just temporarily clip the resistors on, with alligator-clip leads, if you're very careful, just to test it.
Good luck,
The dude.
Posted on Aug 07, 2008
  • 298 Answers
SOURCE: my westfield e4000 les paul
chances are that the contacts in the pick up switch and or volume / tone controls have got dirty over time and are not making good contacts.
The 3 position toggle switches in most budget Les Paul copies are prone to failure - only making contact on one position as the springs get weaker - you could try unscrewing the back plate and examining what is happening in the switch.
Try rotating the volume and tone knobs vigourously to and fro - if this produces a crackling sound the contacts are dirty - further rotation will clean them a bit but a little squirt of switch cleaning spray will help too.
Other than that it could be dry solder joints anywhere on the back of the switches and knobs or poor contact inside the jack socket
Posted on Feb 27, 2011
  • 140 Answers
SOURCE: Suddenly when I toggle to
If the bridge pickup has no continuity, replace the pickup.
I the pickup has continuity replace the switch.
Posted on Jun 10, 2011
Fender troubleshooting
Replace the selector switch. $15 DIY or $40-$50 Pro installed.
Jul 27, 2014 | Fender Modern Player Telecaster Thinline...
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
I bought a yamaha electric it has two double pick ups and a single in the middle the volume knob was no good so i changed it when i opened it up they had the wiring all messed up it has a five pos. switch...
my guess is two positions at one end work(aka 1 and 2, or 4 and 5)? if yes, then 2 of the pickups are wired wrong. (if 1 and 2 work, which are the forward positions, then the middle and bridge pickup are wired wrong, etc.) the problem is there is a variety of 5way switches that are different. i would guess yours is "import" style. are there 8 lugs in a single row on the back of the switch? if yes, you probably have an import switch. best i can do in text is tell you that the middle two lugs are common. this means one goes to the volume pot, and there is probably a little jumper between the two lugs as well. now there are 3 lugs on either side of those 2 common lugs. one set of 3 will probably run to the tone pot in some fashion or be empty. the other set of 3 lugs is for the pickup lead wires. it sounds like at least one or two of those lugs are empty but shouldnt be, or are wired wrong. i cant tell you colors of your wires without seeing it, but this is how it should be, with the exception that the tone knob will probably be on the bottom 3 lugs somewhere. 1 would be the neck pickup, 2 the middle, and 3 the bridge hope this helps, feel free to post a pic of your wiring, etc xadioriderx.jpg
Jun 10, 2011 | Yamaha Electric Guitar
I am looking for a manual (if there is one) for the Epiphone Sheraton II. I need to know which knobs do what (and also the three way switch) on the guitar. The guitar came with no manual!!
Most likely it is wired like most Gibsons. The volume knobs are the two at the neck end, the tones are the two nearest the rear. The lower two are volume and tone for the bridge pickup, the upper two are for neck pickup. Switch down is bridge or lead pickup, switch up is for neck or rythym pickup, and centre position is both pickups one, where all knobs can be used together.
Mar 04, 2011 | Epiphone Sheraton II Guitar Electric...
My westfield e4000 les paul when plugged into anything doesnt work unless its switched to my bridge pickup and turned to 8 volume or lower
Feb 27, 2011 | Music
I need to know how the five way switch works. I don't know which switch position turns on which pick ups.
In a guitar with 3 pickups a 5 way switch works like this. With the switch all the way forward( towards the tuning pegs) the pickup closest to the tuning pegs or end of the neck is completely on ( if your volume control is all the way on). The next position (moving away from the tuning pegs or neck) is a combination of the neck pickup and the middle pickup. The third position moving away from the neck is completely the middle pickup. The fourth position is a combination of the middle pickup and the bridge ( where the strings are fastened) and the fifth position is completely the bridge.
Nov 15, 2010 | Washburn Electric Guitars Modelno X11B
Epiphone Black Beauty controls don't seem to work properly
The volume is a common problem ... Search for wiring diagrams for your guitar to find a better wiring. Or take it to a guitar repair centre to have it fixed.
To tell which pickups are selected with the switch if it doesn't have the little plate telling you, Turn one volume down and flick the switch one way so you can hear just one pickup.
Two ways of telling which one it is picking up ... A toppy tone is the one nearest the bridge ... a bassy tone is the neck pickup ... The middle selection on the switch is both coils selected ... If you cant tell by tone ... Tap the pick up and you'll soon hear which one you have selected.
Apr 18, 2009 | Epiphone Les Paul 100 Electric Guitar
Good luck,
The dude.
Aug 07, 2008 | Dean Dimeblade Tribute Electric Guitar
Music Logo
44 people viewed this question
Top ESP Music Experts
Michial Gueffroy
Joseph Hoffmann
Are you an ESP Music Expert? Answer questions, earn points and help others
