Question about Hitachi Ultravision P50S601 50 in. Plasma HDTV
Volume control not working. sound is full blast no matter the setting
We power the TV off and back on until it turns on normal volume (sometimes takes 5-12 times powering on and off)
4 Suggested Answers
  • 3 Answers
SOURCE: can not change inputs.
seems to be fixed. the only change was a shot surge ptotector. if its a short the problem will return.
Posted on Mar 24, 2009
  • 321 Answers
SOURCE: Have a p50h401. In last week a few times, power
yes you have some few fan in the if they doesnt work it will hover heat thats could from the fan power voltage from the prower supply or the fan it self
you can try an external fan and blow the air on
the back panel in the aeration notch if it stand
thats your problem the circuit came over heat
hope that will help
regards Alan
Posted on Jun 07, 2010
Testimonial: "Thanks for your input"
  • 6 Answers
SOURCE: TV does not power on. For the last several months
I have similar problem with my 42hds69. What I did is unplug the tv and remove the cover and vacuum everything especially the fan and remove the power supply board and brush/vacuum the back side... careful about static so hold the metal frame while you're vacuuming. Reassemble everything... mine worked... and still working... Good luck.
Posted on Aug 07, 2010
How can I fix a Samsung TV on which the volume is on full blast when turning the set on, not matter what it was set on when turned off.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 10, 2015 | Samsung Televison & Video
Tv volume control
the volume controler board on the tv could be at fault. the button could be damaged and connecting the circuit making the volume go up. failing that there is a cross feed some were on the feed were the wire from the control buttons go to the main board, dust a damp can cause this. or even just dust.
Jun 21, 2017 | Coby Audio Players & Recorders
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Crate pa-b8350 While playing for a few minutes, it will fade out volume until you either turn a channel volume, master volume, or reset power. Neither of the 3 "fixes" mentioned above works all...
That sounds like a volume control IC that has become heat sensitive. In other words when it's cold it's normal and then when it's been on for a while it warms up and develops the fault. You can search for the faulty part by spraying it with Radio Freezer Spray. Do one part at a time. Wait for it to play up and blast it! If it goes back to normal you have found the faulty part.
Mar 06, 2013 | Audio Players & Recorders
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
I have to turn them up full blast for normal sound
did it work louder before?, volume up all controls. anyway you can't expect a lot from this normal use speaker, this only for sounds not for entertaining.
Dec 21, 2010 | Dell AX210 2 Speakers
My speakers wont´t work! i plug them in and I can´t hear anything! it´s not usb !
Be sure you have the plugs in the correct holes.
Feel free to move them around. The bezels on the sound ports are often color coded and will match the plugs you have. SOMETIMES they are not and you must guess.
Also make sure your sound settings have not been accidentally set to MUTE. Turn the volume up and play some music files or anything with sound.
If these speakers use power from the household plug.
Be sure the power knob is turned on! Usually the volume button.
If no external power is supplied these usually must be turned up full blast just to hear them. Some on board sound systems do not have the power to push the these speakers very high.
If all else fails
Update and make sure the correct sound drivers are loaded for your system.
If you have another set of speakers. Try them!
Cheap doesn't matter here.
Your only trying to determine the output works.
If it works then the other speakers may be defective.
Hope this helps!
Oct 04, 2009 | Compaq Audio Players & Recorders
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Hitachi Ultravision P50S601 50 in. Plasma HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
