Question about JVC TH-M303 System
Auto muting My JVC TH- M303 is showing auto muting. I cannot get it to turn off. The DVD or CD's will play, just no sound. One morning i turned it on and heard a loud noise kinda like feedback or something and it has not worked since. Any ideas. Thanks.
    New Friend:
I found and article that said one of the defective parts that causes this is an open R2702 resistor. It's a 470 ohm resistor found in the subwoofer component. I opened up the subwoofer and found it back on the right hand side near the transformer. I used alligator jump wires to connect a good 470 ohm resistor across the existing resistor to test it, and IT WORKED!
Getting at the circuit board to replace the resistor is going to be a nasty project. My advice: If you don't actually have 470 ohm resistors lying around your place, you probably don't have enough electronic knowledge to repair this unit. Get a friend who is comfortable with electronics to do it for you. Their labor (a couple of beer) will be much cheaper than a repairman. The resistor costs about 2 cents (I buy in bulk - 470 is a commonly used value), so it's a shame to hand out about $100 to do the repair.
Testing the resistor is easy. To open the unit up, there are a bunch of screws on the bottom and a couple of screws on the side. Then the electronics slide out of the box. NOTE: You will have to disconnect the wires to the subwoofer speaker to slide out the electronics. Then you can reconnect the speaker to test it. BE CAREFUL! There is enough exposed high voltage to fry yourself on the board!
Posted on Apr 23, 2017
  • 103 Answers
Sounds like something inside went south. You can try disconncting the speakers and see if it still happens. If so, then the system is in need of repair. If not, then a speaker may be shot. Try connecting one speaker at a time to see which one may be causing the auto-mute problem.
Hope this helps, and please rate my advice, good OR bad.
Posted on Feb 04, 2008
Th-m303 sub dont sound when playing dvd
Please try and connect the DVD using the coaxial or the optic cable so that the input is seperated to perrform on the amplifier with a true DTS.
Oct 26, 2011 | JVC TH-M303 System
Sub would only sound when am listening to radio would not sound when playing dud aux but surround speakers play
Possible that the connection to the AUX does not activate if you are using RCA inputs. Connect the DVD using the optical cable or the coaxial link and it must play better with surround and subwoofer in DTS.
When i put the fm radio it display auto muting and doesnt have sound, this only happens with the radio because the dvd sounds ok
"Auto Muting" in the context of FM means the output will be muted if the signal is so weak it would result in mostly noise anyway. Interstation radio noise can be annoying and dangerous at high volumes.
Aug 14, 2011 | JVC TH-M303 System
My dvd player is locked
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
Jun 17, 2009 | JVC TH-M303 System
Th-m303 theater system no sound coming from all 5 speakers
Review the wiring connection maybe loose contact and check the speakers If it workings by testing the one not working to put or interchange it to the working speakers, so you can sure if the speakers is fine. Check also the selector assignment.
Hope it may help you;
Jan 11, 2009 | JVC TH-M303 System
Will not play dvd,will not eject dvd
We had the same problem and found we had a disc stuck in there... I stronlgy advise not to open it unless you have some idea on what to do. We opened ours and got the cd/dvd out and luckily it still worked!!!
Jul 24, 2008 | JVC TH-M303 System
Remote Control
check your switch on the right hand side is set to audio
Jan 14, 2008 | JVC TH-M303 System
Subwoofer shuts down
Check the connection in the back of the sub,where your wire plugs in from the DVD unit, the connector is loose in the unit itself. Had mine replaced and is doing the same thing again
Nov 24, 2007 | JVC TH-M505 System
No CD sound on Philips DVD/VCR player
I havent seen this model But in the past I have heard this problem arise. It turned out that there was a mute button for the cd only on the remote and there was no indicator to show it. check for a cd mute or go into the cd play menu and check around in there.
Mar 23, 2006 | Philips DVD740VR DVD Player/VCR
JVC TH-M303 System Logo
685 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
