Question about Sony HDR-HC1 Mini DV Digital Camcorder
(1) lcd not working properly (only when you turn it 180 degrees and place it against the camera body will it work, (2) tape load mechanism won't except tape, it continues to eject tape
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • Sony Expert
  • 65 Answers
Posted on Aug 31, 2015
C-m0n3y
  • 34 Answers
SOURCE: LCD Screen Turns Blank with i rotate it 180 degress
Seems like the cable is damaged. You should get it fixed by SONY.
Posted on Feb 24, 2008
Bubbabear64
  • 2794 Answers
SOURCE: tape loading
You should take it into a camera shop and have them inspect it. Those assemblies are pretty detailed. They have the tools to fix the problem.
Posted on Aug 12, 2008
welcomejee
  • 10594 Answers
SOURCE: The camera will not load a tape
Symptom shows Dew sensor is activated and most probably you will see water-drop yellow sign flashing in LCD.
Remove battery / power source from camcorder and leave it for 1-2 hours, reattach battery/ power to camera and turn it on and check.
Thanks.
Posted on Nov 05, 2009
SOURCE: loading tapes
Sony HDR models that the carriage won't close is caused by the mode switch on the chassis. The mode switch controls the cameras function for loading and loading of the cassette. Basically tells the electronics what is happening. This becomes dirty and causes the chassis not to complete it's cycle on eject. Thus staying open. It has no idea where the mechanism is at this time. It can be cleaned and realigned but the chassis needs to be removed to get at it. Definitely a service depot repair. Sorry!
Posted on May 02, 2011
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
LCD screen working only if turn counterclockwise
make sure you open the lens 90 degrees to the camcorder.normal operation of the cam will allow you to rotate the lcd to a maximum of 180 degrees and can eve close it with the lcd screen side facing out. you can try pressing the reset button.if it still won't work try removing the battery and unplugging it from the ac adaptor for at least a minute.if still doesn't work properly,issue could be with a bad ribbon inside the lcd that loses contact when you turn it clockwise.that of course would need replacement or repair.
Dec 06, 2009 | Sony Handycam DCR-SR80 HD Camcorder
The camera will not load a tape. Without a tape installed the loading mechanism works as it should. when a tape is placed in the camera it does not retract into the camera but opens back up as if to eject...
Thanks.
Nov 05, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Tape loading
Aug 11, 2008 | Sony Handycam DCR-TRV38 Mini DV Digital...
Feb 24, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
No image on lcd for Panasonic nv-gs50 camcoder
It was my question and I have found an answer.The problem was,due to faulty main PCB,which did not supply power to LCD backlight. I was lucky enough to find same faulty model on eBay,sold for spares (around $15 for the lot).I have also purchased a service manual for $10,just to see,how to disassemble a unit.It was pretty easy,not a rocket science.Any new replacement part usually very expensive,not saing about repair in repair shop.Will cost fortune.My advice: try to find similar not working unit on ebay,just figure out what was wrong,as there is no point to get unit with the same fault.The camera I have bought for parts had a mechanical problem,chewing tape.
Jan 22, 2008 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony DCR PC101-E
your lcd flexwire  is bad, you need pro help to fix it.
Oct 29, 2007 | Sony Cyber-Shot DSC-P150 Digital Camera
"Push the reset switch"
I had the same problem with the 'push the rest button' on the display after the tape mechanism jammed up against the tape compartment cover. I figured there was probably a mechanical error, possibly a switch. I dissassembled the camcorder and found the tape compartment cover switch was sticking. Here's how to fix it with some photos to illustrate:
1. Open the tape compartment door and remove the screws in the small plastic cover (fig. 1). Remember to look a which screw came from each hole as they are all different.
2. Remove the plastic part from above the tape mechanism (fig. 2)
3. Remove the screw above the front grip belt mount (fig. 3)
4. Remove the screw above the mic (fig. 4)
5. Remove the battery and take out the screw at the top left under the viewfinder (fig. 5)
6. Take out the screws under the LCD monitor (fig. 6)
7. Remove the two screws from the front underside of the camera body (fig. 7)
8. Now you can slide the front of the camera, together with the curved aluminium top section away from the main body of the camera (fig. 8)
9. It is possible to reach the switch with the front moved forward slightly, but it is possible to take the front off entirely by removing the wiring ribbon with the green tab (fig. 9)
10. Clean the brown switch at the bottom left of the exposed camera front with a soft brush/air (fig. 10 )
11. Reassembly is the reverse of the above procedure.
Hopefully this will mean no more frustration with the 'press reset button' screen.steviedeee.jpgsteviedeee_0.jpgsteviedeee_1.jpgsteviedeee_2.jpgsteviedeee_3.jpgsteviedeee_4.jpgsteviedeee_5.jpgsteviedeee_6.jpgsteviedeee_7.jpgsteviedeee_8.jpg
Jan 21, 2007 | Panasonic NV-GS15 Mini DV Digital...
My camera will not turn off !!!!!
WOW: All three Solutions Work Fine.
I Removed the 6 small bolts and took the camera apart.
lifted the tape and cleaned the contacts u;nder the tape with alcohol, let them dry then replaced the tape, lineing up the contacts on the tape with the ones on the body of the camera. Put the camera back together and put back the 6 bolts, inserted the batteries and presto: the camera worked. Thanks for the info , it really worked. Wes Reed
Sep 11, 2006 | HP Photosmart M407 Digital Camera
Sony HDR-HC1 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
