Question about Sharp XE-A207 Electronic Cash Register
How to sign clerk on - Sharp XE-A207 Electronic Cash Register
How do I sign on and get rid of the E008! How do I put a clerk in there so I can sign on
Hi. You just type in your clerk id number and press the CLK# (clerk) button. That will remove the error and allow use of the register. If you've forgotten your secret ID code, you can program a new one. One of the users has most manuals here:
https://the-checkout-tech.com/
Jan 11, 2016 | Retail Supplies
This register appears to be ''closed''. Every mode states to be closed
closed means there is no clerk signed in. if either pressing the clerk button at the top right of keyboard or pressing 1 clerk does not sign in a clerk it has probably lost it's programming. to reset to factory condition turn the C key to six oclock position and unplug then reconnect plug while holding down the double zero button
Jan 03, 2014 | Sam4s SAM5215 Er-5215M 1
Clerk sign in
Go to Casio Support Webpage and download the Owners Manual.
Here: http://www.casio4business.com/sa/support/downloads/downloads_manuals.html
Dec 17, 2013 | Casio PCR-T2100 BLACK DELUXE 96-DEPARTMENT...
I am not sure if I program clerk numbers yet, but I can not sign on my PCR-T470 I keep getting E008, and I tried 1 Clerk, 2 clerk, etc... and I get no where. Any suggestions?
That surgest you have no clerk numbers yet as the error E008 = Not signed on, working without a clerk number i have uploaded a manual for this on my host HERE i hope this helps
Oct 16, 2013 | Casio PCR-T470 Cash Register
How do i get rid off the error code E35 (CNG OVER), and also how do i remove clerk sign in, so i dont sign in anymore on the TE 2000 CASIO
It sounds like someone has accidentally programmed a limit into the CASH button. Try this:
Turn key to program 0 cash subtotal 3 subtotal 0 cash subtotal
You must use at least one clerk. the machine will not operate without a clerk logged on. You can use the machine features in the manual to stop a clerk log off after a sale if it has been turned on. Then a clerk will stay there.
If anyone needs a Casio TE-2000 manual, c-tech collective have them here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jan 22, 2011 | Casio Parts Cash Register PC Desktop
How to set up 4 clerks on the key board of casio tk2700 cash register to be used as multi user
The 2700 has to be set to sign on clerks straight after a RAM clear if you want this feature, otherwise you use the buttons next to the mode key to change clerk. Try the buttons first to see if they are changing clerks. If not, then you can have sign ons. If they are, you are stuck with this unless you clear the whole machine and start again
Dec 16, 2010 | Casio Parts Cash Register PC Desktop
Casio Cash Register, I Need Details On Clerk Function , And How To Use It. Model : PCR-T470
The clerk function is used to log sales under staff numbers. It is usually used when you pay your staff by commission, or you want to track particular sales by certain staff.
To sign a clerk on, type a clerk number and press CLK#. By default, the clerk numbers are 1, 2, 3, 4 etc. They can be changed if you need secret codes.
To sign a clerk off, press SIGN OFF
Hope this helps. If you need more info on clerks, just let me know.
Anyone looking for a Casio PCR-T470 manual? There is one here: http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T470_users_and_programming_manual.html
Oct 31, 2010 | Casio Parts Cash Register PC Desktop
Sharp XE-A207 Electronic Cash Register Logo
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
