Question about Garden
Change blades on briggs and stratton 500 series
5 Suggested Answers
SOURCE: pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Posted on Jul 02, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Briggs & Stratton 500 series push lawn
Hi and welcome to FixYa, I am Kelly.
When a primer bulb is slow to return to a static conditon there is a restriction in the fuel supply. Since this carb is mounted directly on top of the fuel tank the troubleshooting for this involves removing the gas tank and carb as an assembly from the engine. Remove the end bolt and then the side bolt spacer that is just above the tank. Be careful or the spacer will drop. Pull out on the tank until it slides off of the intake. When the tank is free of the engine tile the bottom of the tank toward you and disconnect the throttle linkage. NOTE the hole the linkage is connected to! Set the tank on a flat surface and remove the carb mounting screws. STOP! Do not lift the carb off of the tank until your sure that the gasket and diaphragm are not stuck to both mounting surfaces. You may have to carefuly slide a thin knife blade FLAT across the top of the tank to free the carb from the tank. There will be a SPRING on the bottom of the cabr also. Do not lose this spring and ensure you see how it is installed! Once the carb is free of the tank clean the screen under the carb and the carb with carb cleaner. Reassemble carb to tank. Fill tank with gas and re-check primer bulb BEFORE you reinstall the tank and carb on the engine. If it still does not work.. properly you need to clean the passages again. Worst case you remove the primber bulb to see if there is debris inside the bulb plunger area. Installing tank and carb to engine....
Tip the bottom of the tank toward you.. connect the throttle linkage, watch the o-ring that is in the carb intake sealing area and make sure it seals. Install side bolt and then the end bolt.
Just back tracking here.. I have determined this is most likely a 11A-B04E000 Yard machine with a 5.0 Hp engine... ( Briggs and Stratton refers to this engine as the 10T500 series.
ENGINE Parts list is here:
http://www.brandnewmowers.com/pdf/11A-104B090EIPL.pdf
Thanks for choosing FixYa,
Kelly
Posted on Jun 28, 2011
Knucklebstr
  • 222 Answers
SOURCE: poulan pro w/ 550 series
Your carburetor needs a good cleaning or a rebuild kit, depending on its condition once opened up. There are tiny holes (jets) in there that easily get clogged or gummed up with today's crappy gas (ethanol). This is the problem with 90 percent of the machines I work on or fix. If you don't know carbs, then I recommend you take it to a professional and have the carb done (30 to 40 USD, probably), but it should run like new, once this is properly done. If you are a "do it yourselfer". then you can find plenty of videos on youtube to help you get started. Just pay close attention to what goes where when you take the linkage apart. Trust me, do not leave it to memory; take photos. Best of luck to you.
Posted on Jul 02, 2011
Testimonial: "Much appreciated. Giving me an idea of what to look for as well as where I can go for further information is extremely helpful. Thanks. -Jake Towley"
stapes613
  • 6 Answers
SOURCE: have a 22inch yard machines push mower with a 500 series briggs and stratton with diaphragm type carburetor, will start up and run but no longer than 30 mins, after a couple minutes of running the mac
to me that sounds like a problem with a bad coil
Posted on Jul 28, 2012
How do I change the oil on my new Briggs & Stratton 500 series 140 ohv lawn mower?
It should have a drain tube out the side of the engine, but if it doesn't it will always be left handed threads. Hope this helps you.
Dec 04, 2016 | Briggs & Stratton Garden
Where is the plug to change the oil?
Amy, if drain is not in the bottom of engine by blade, turn mower on it's side to drain oil to change.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change your Briggs Stratton engine oil
Toro 6 5hp GTS Oil Change mpg
Mar 26, 2016 | Poulan Pro Pr550n22sh 22-Inch 140cc Briggs...
How to change blade boss on briggs &stratton sp 470
Unscrew the central bolt (9/16") - remove blade and any washers etc. It's a conventional right hand thread (anti-clockwise to remove), but may well be extremely tight. If necessary, grind the head of the bolt off and replace it.
The blade boss slides off the shaft - in theory. In practice, you will probably have to use a puller bearing on the blade bolt to pull it off. Remove the drive belt first!
Sep 21, 2014 | Briggs & Stratton Briggs Stratton...
How do you check the oil in a Weed-Eater-500-Series Side Discharge Mower, Model 10854261. It has a basic Briggs Stratton engine. I have a lost the manual and cannot figure it out!! HELP!!!!
most mowers have a dip stick like a car and the oil should be changed often and acting as if it wants to stall try fresh fuel gas is only good for 30 days in small engines
Mar 27, 2012 | Briggs & Stratton Garden
Pull cord wont pull,briggs 500 series
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
