Question about Canon CP1200-D Calculator
Calculator wont print
After I have taken it apart and back together
I dropped juice on my cannon mp-11dx calculator is it possibleto open calculator and clean keys ?
You have nothing to lose!
I have successfully cleaner many keys in calculators and keyboards.
You might want to take pictures as you take it apart, so you can successfully put it back together after you clean the keys.
Good luck.
Paul
Aug 08, 2016 | Canon MP-11DX Calculator
Nothing happens when I press the zero key on my Canon P170-DH calculator
Probably dirty. I would take it apart and clean that key. You might take pictures to ensure that you can put it back together correctly.
Good luck,
Paul
Jul 30, 2016 | Canon P170-DH Printing Calculator
The #5 sticks, how can this be corrected / repaired?
I would take it apart. Be sure to label parts, take pictures, so you can put it all back together. Some drink probably got split on it, so it sticks. Just clean it with a damp cloth and make sure it has stopped sticking before you put it back together.
Good luck.
Paul
Apr 25, 2016 | Canon MP18D II Printing Calculator - CASE...
My ti-84 plus got wet and now wont turn on
the only thing that I can recommend it to stick it in a zip-lock bag full of dry rice for 24hrs. Sometimes there is moisture that you just can't see & rice has a way of attracting liquids from electronic components. Hence, potentially saving your electronic device. If this does work -- if I were you I would suggest always storing your calculator, ritually, in a zip-lock bag so this does not occur again (I do this -- TI-84s are not cheap accessories -- better safe then sorry). Good luck!
Sep 01, 2014 | Texas Instruments TI-84 Plus Calculator
Do i need to have my 2004 dodge intrepid anti theft code reset through a dealership if the heads and head gaskets were replaced? the entire top of the engine ws taken apart adn put abcl together.
i would disconnect the battery. removing both the positive and negative battery terminals. with both ends disconnected, hold the two terminals together for about 10 seconds. this will proform a hard reset on most chrysler vehicles. also, if this doesnt work, try turning the key to the on position, and then proforming the hard reset procedure.
Nov 04, 2012 | Dodge Cars & Trucks
Canon CP1200-D Calculator Logo
old marine
old marine
