Question about Panasonic Heating & Cooling
Timer light flashing, unit wont stay on - Panasonic Heating & Cooling
3 Suggested Answers
  • 653 Answers
SOURCE: My Fujistu AST9LSACW split system
There are two things you can check outside before calling a service technician. The first is the breaker to the outside unit. There is a breaker or disconnect near the unit. If there is nothing wrong with the electrical supply, check the refrigerant level. If the level is low, the pressure switch will cut off power to the compressor to protect it from damage. DO NOT try to recharge the compressor yourself.
Posted on Jan 30, 2011
  • 119 Answers
SOURCE: Daikin FTY45EV1A split system wont turn on, has
The only thing I can find on "Daikin FTY45EV1A" is on Russian, and I don't read that language. If you have a manual for that system then find the section on error codes and see if that flashing light gives you a pattern. Usually they flash in two sections giving you a two digit code. I.E. 1 flash pause then 3 more flashes would be a 13 code. Read your manual and see if it gives any help.
Posted on Jun 14, 2011
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Timer light stays flashing all the time how do i get it to go out?
You need to go in the on screen menu and set your clock. This will stop the flashing.
Aug 30, 2014 | Quasar VHQ400 VHS VCR
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Daikin FTY45EV1A split system wont turn on, has flashing timer light on. I turn the unit on and off by the remote, still doesn't work. What does the flashing timer light mean?
Jun 14, 2011 | Heating & Cooling
My Fujistu AST9LSACW split system air-conditioner wont blow cool air. the outside unit AOT9LSAC doesnt seem to be working at all. The power light stays on but the timer light flashed about 15-20 times a...
Jan 30, 2011 | Fujitsu Heating & Cooling
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Power problem
require your complete model number for the rear of the unit,please
Mar 19, 2008 | Samsung HCN473W 47" Rear Projection...
Heating & Cooling Logo
10 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
