Question about One For All URC-3021 Remote Control
Toshiba tv code
Code for a toshiba tv
Gigatech
  • 259 Answers
SOURCE: NEED CODE
Celera 0765
Magnavox 0054, 0706, 0030, 1454, 1254
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Posted on Dec 12, 2007
Gigatech
  • 259 Answers
SOURCE: I need a code for a Toshiba TV remote and a Cyberhome DVD Player
Try searching for your code. If it is not listed in the manual. Here are the instructions to search for your codes:
your code.
then release SET.
key, you can substitute another function, such as digits 0~ 9 ,
CH, or PLAY).
first.
blink twice.
Here is your manual:
http://www.ofausa.com/remote_manual/CTGAE3P%203021%20anual%20booklet.pdf
headstrong
  • 233 Answers
SOURCE: i lost my code for a Toshiba TV
GET IT HERE
Thanks for rating
Posted on Jan 12, 2008
ctf1800
  • 4402 Answers
SOURCE: tv remote setup code for toshiba
Remote codes
http://www.remotecentral.com/index.html
Posted on Feb 22, 2008
SOURCE: need code for toshiba tv
I need codes for my Panasonic Tv/vcr. I have a One for all URC 4220 remote control
Posted on Apr 08, 2009
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
Need Remote Controler Codes for Toshiba Remote for Toshiba Model TP61H60 a 1998 Big Scrren
Your Toshiba remote should have the necessary codes to control your Toshiba TV unless one is much older than the other.
If your RCA remote is programmable, you can use its "code search" feature to find an applicable code or codes. If a complete search of all codes stored in your RCA remote fails to find a code, you may have to try another programmable remote or simply wait until the replacement Toshiba remote arrives.
Sep 25, 2014 | Televison & Video
Can`t find the code to use my toshiba tv control to work my direct tv satellite to change the channels
try working it the other way, input the code to work your toshiba television from the direct tv remote.
Sep 13, 2014 | Toshiba 40RV525R 40 in. HDTV
UNLOCK TV TOSHIBA
Call Toshiba @ 1800_618_4444 with the same information you provided here, or use .http://www.toshiba.com/tai/americas/index.jsp
Aug 07, 2014 | Toshiba REGZA Televison & Video
How do i put a code on my urc 11-1625 remote for the Toshiba T.V and could i also get the code for the Toshiba television ?
Set up codes for Toshiba TV are:
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 26, 2012 | Toshiba Televison & Video
I need the codes to program a panasonic vcr into my toshiba tv remote
The code of panasonic vcr on your toshiba tv are : 14 or 51 and or 59. Try one by one the code above until the vcr work on your TV.
How to do?
1. Press the code button 2. Press the 2 digits code
Regards, Jay
Sep 14, 2009 | Toshiba 50H82 50" Rear Projection...
Need code to program toshiba tv with Direct tv remote
I HAVE A TOSHIBA 32A33 TV AND JUST UPGRADED MY RECEIVERS AND REMOTES I CANNOT GET THE DIRECT TV UNIVERSAL REMOTE RC64 CODES THAT THEY HAVE PROVIDED TO WORK, ANY ADDITIONAL CODES ? PLEASE HELP
Dec 06, 2008 | Directv RC23 Remote Control
Can't find code for my RCR312W to work on my Toshiba TV. I tried all different codes. Any suggestions?
Have you tried these codes?
Code 1000 for Toshiba TV Code 1048 for Toshiba TV Code 1072 for Toshiba TV Code 1105 for Toshiba TV Code 1109 for Toshiba TV Code 1118 for Toshiba TV Code 1160 for Toshiba TV Code 1190 for Toshiba TV Code 1241 for Toshiba TV
Sep 10, 2008 | RCA Universal Remote Control
Need code or codes for my Philips Universal Remote to a Toshiba TV
please tell my what code for philips universal remote pm 435s?for my tv sanyo?thanks?
Aug 15, 2008 | Philips PM435S Remote Control
One For All URC-3021 Remote Control Logo
15 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
